possible drive shaft knock ?
just a quick question, my car has been parked up at college for a few hours, got back in it to go home, and it has developed a knock from the front passenger side, its more of a knock rather than a click, it gets louder and faster as you go along, (obviously), does anyone know if this could just be the cv joint or the actual drive shaft ? or possibly a track rod end ??, thanks
Cable tie around the driveshaft?
What is it like on full lock?
HDi Cabby Project Click
gets louder on full lock, however it does happen while driving in a straight line.
(28-01-2013, 03:55 PM)brad306 Wrote: gets louder on full lock, however it does happen while driving in a straight line.
Id say driveshaft!
Has it been like tgat for a while? Sounds pretty shagged
^Agreed, get your head in there and check the condition of the inner and outer cv boots, if they are split then expect the joints to be on their way out, you may get away with packing them with grease and changing the boot but for the hassle you might as well just change the cv as they're only cheap.
http://www.ebay.co.uk/itm/PEUGEOT-306-1-...619&_uhb=1
Wheel bearing Smile
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
If it was a shaft you'd get steering wheel wobble like the wheels are un balanced.
Had this on mine it started quiet and got louder over the weekend. Got a new shaft was only when I was removing the hubnut the middle fell out and the ball made a runner down the drive.
Blaze 1.6 Dead
Check the p bushes. The wishbone moves around a fair bit If the bush has collapsed
  Diesel Knock pugtk 2 3,198 16-07-2016, 05:41 PM
Last Post: Mattcheese31
  Low fuel cause bad knock HDIkyle 1 2,171 27-02-2015, 09:51 PM
Last Post: HDIkyle
  bad knock, pump? randomcaller 8 4,948 29-06-2014, 01:15 PM
Last Post: randomcaller
