Clonking, front end turning right...
Place your bets, what do you reckon this will be?
A knock, which occurs when turning right (not full lock). .....knock knock.......knock knock.......knock knock......
Etc, which is consistent with the road speed.
I know it's impossible to diagnose without getting it on a ramp I'm just curious to hear what people may have experienced themselves and what the solution was. I'm thinking drop-link but will get it on a ramp asap...
[Image: Sig500x130.png]
Tre or droplink
I'd guess at droplink if was full lock I would have said cv joint
wallet hitting the floor paying someone to repair it
(28-01-2013, 10:37 AM)cully Wrote: wallet hitting the floor paying someone to repair it
Or his belt buckle
Snapped spring?
Ah yea, could be a bollox'd spring.
Good excuse to hit it with the lowering stick then eh?
Actually hoping for a broken spring now! What are the best springs to get the front end of an HDi down (standard shocks?) I've used 40mm in the past but it tends not to do anything much...
Well depends what your going for.
You have a baby so pushchair and stuff so you want something practical so get a decent set of 40mm. If it has the right weighted springs should be ok.
But if you have 15" then 60mm should look good.
Possibly balljoint.
Possibly as silly as me.
Lowered the car, left top mounts out
How do you lower a car and leave the top mounts out?!
This^^ Huh
Drop link, or CV joint but that's usually only under load.
Managed to 'borrow' a garage this Sunday which has a 2-post lift, thank fook! Will have a good prod around. Fairly sure it's going to be drop link though as it's eerily familiar...
something on the right!
My money is on the top mount bearing!
(28-01-2013, 09:58 PM)Ollie Wrote: My money is on the top mount bearing!
Never had to replace one of these. Pressume you need to remove the shock entirely?
Here's hoping it's the drop link lol
Yeah and you need spring clamps but its really not that bad a job at all!
Can't imagine knocking being the top mount bearing... Should be pretty obvious if it's up top or at the bottom too...
Getting worse now.
I suspect it really is the drop link on the drivers' side, is it worth buying them in advance? Can't hurt changing them anyway.
Back in't day the Lemforder jobbies were the bees knees, is that still the case? I don't want adjustables, just replacements...
(29-01-2013, 01:55 PM)C.A.R. Wrote: Getting worse now.
ahh droplinks are droplinks pretty much as long as you don't buy uber cheep shit, i always get plastic ones at about 20 quid for the pair . . Smile
Aye thought as much.
There are some on ECP but they appear to be £24 each! F*ck that.
I got metal ones from my factors for £14 a side
Try gsf think there bout £12 mate
Potential problem...
Knocking has gotten much worse, but I have noticed this evening that it will only knock in-gear. If I coast in a car park I get no knocking.
Panic. It's a driveshaft isn't it?
Should I continue driving the car or is it likely to shit itself?
If my suspicions are correct then how easy is a driveshaft change and at what cost?
driveshaft isn't hard, well the hard bit is undoing the hub nut, just pull old shaft out push new/secondhand shaft in, obviously you will have to replace gearbox oil as well . . . .
£47 for a new one.
Is it dangerous to drive like this? I can get a lift to work if necessary.
No it's not really dangerous if you get it done soon enough and don't drive like a knob.
Yeah I finished mine off by accelerating fast and then breaking very hard.
Just remember to remove the hubnut before anything else!
I understand the hubnut is a bitch of a job. I'm sure we'll have the tools (father in law is ex-mechanic) but worried about undoing it on axle stands. People say to leave a wheel on but I have cyclones - no centre hole...
  Rear Beam and Brake squeeking while turning? JTaylor2005 5 3,658 20-10-2016, 03:37 PM
Last Post: JTaylor2005
  Clonking sound from rear of the car.. HubbzPug 2 2,641 04-08-2014, 09:49 AM
Last Post: HubbzPug
  Reversed over a kerb, groaning noise turning right rtha6551 3 2,967 22-08-2013, 10:41 AM
Last Post: LJ_D
