EGT average temps
For people with EGT gauges, what EGT's do you get, after a quick blast through second and 3rd?
Just interested to know really, I don't think my 9mm is anywhere near maxed, and a quick blast through 2nd and 3rd will see 600+ very quickly. Will be interested to see what people get, especially on pumps on the edge of running away lol
GT2052s DTurbo
OEM+ HDI Estate
Project thread
That's pretty normal, when blasting mine I could easily see 850c on a warm day, keep going and you could see 900+...
il be installing my egt gauge soon, im interested, what temperature should you try avoiding? i.e. when does damage to the head start to occur?
900+ from what I've seen isn't good lol
I expect my little turbo will be a lump of molten aluminium with a lot of 900 degree runs!
GT2052s DTurbo
OEM+ HDI Estate
Project thread
long hard haul, mine sees just over 900, but a thrash through 2nd and 3rd will only see about 700... its when its loaded up in 5th for ages it hangs high for me...
Thread revival alert!!!
Had a "spirited" drive to work this morning and thought I would post the results.
EGT
Temp before toe down (xud warm up) - ~ 200*C
Blast through second/third - quicly ran up to ~ 650*C
Sustained run in 5th foot hard down - ~ peaked at 850*C
Motorway cruise speed - returned to ~ 250*C
Oil pressure
Sits around 60psi while idling cold
Drops to 35psi idling warm
Peaks around 70psi when under heavy load
Boost
Full load pre charger 18Psi
Full load post charger 30psi+
Idle 7psi pre charger ----> WIN!!!!!
Water temp
Idle once warm ~ 75*
Full load - Gets to 90* rather quick!!!
Cruising - Returns to ~80*
I will update this again once I get my oil temp gauge working
HDi Cabby Project Click
Have you got your EGT sensor installed before or after the Turbo??
Pre turbo mate
Good Info, I'm getting my EGT-Probe installed this week!.. Finally it will stop reading Outside Air temps! Smile
Suzuki Santana Vitara 1.9 Td (Xud9) 3Dr
For anyone else reading this - absolutely zero point in having a sensor post turbo. It doesn't respond fast enough to the temperature changes and is a good few hundred degrees below what the turbocharger is seeing - let alone the exhaust valves and cylinder head.
Might as well lick your finger and hold it in the breeze outside for the good one post turbo will do.
  SoS urgent...xud estate temps Piggy 25 13,373 22-06-2016, 07:36 PM
Last Post: The Phil Billy
  thermostat opening temps...lower temp' stats? Piggy 25 15,729 25-01-2015, 05:10 PM
Last Post: Piggy
  Temps / Gauge Informaton Needed silverzx 3 2,790 17-07-2013, 04:15 PM
Last Post: silverzx
