door locking with light switch
right my drivers loom is shot and no longer there so no electric. passenger is connected but the window will not work and fitted a new motor. when the passenger door is shut if i turn the lights on it locks. is this a short some were easy enough to be found?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Please tell me which language to use ?
http://translate.google.co.uk/
Pretty sure the passenger window switch works through the drivers switch...if theres no power to the drivers one the pass won't work.
And whats the passenger loom like? Knackered probably.
yep thats true. the passenger side works through the drivers side D:
sorry for the crap writing.
i do not have a loom connector on the drivers side because the loom is dead so no electic in the drivers door at all
passenger window also doesnt work. ive fitted a new motor and the switch lights up but it is not making a noise
Ph3 perv cab heaven
Black ph1 XUD died
Pull the looms out and see what the state of them is, is your best bet.
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
You say there's not even a plug? Do you need one to fit?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Would of thought you need to repair the door looms before you'll stand a chance of fault finding. Especially with peugeots electrics Wink
Indeed, sort the looms before anything else. Smile
  Brake light switch parts exploded view pug306driver 11 10,074 13-12-2021, 06:11 PM
Last Post: Mighty306
  Brake light switch pug306driver 10 8,572 14-10-2021, 01:18 PM
Last Post: pug306driver
Wink Door Loom Swapped - Central Locking Fault! partybish 8 6,913 29-09-2017, 08:58 PM
Last Post: paulgtt
