Help please. Drivers side door wont close
Help please went out to the car bout 10min ago and opend the car like normal n then wen i closed it behind me it just wont close. Its like thers something blocking the door. Iv tried the normal stuff likenplaying with the lock but it just wont close. Just bounces open agane like the lock aint even catching any suggestions? An a bit stuck otherwise [/align]
when in doubt...... flat out.
It sounds like it might not be aligned properly, if you lift it up slightly as you close it, it should hopefully close.
Nice one will try it in a min.
Not worked Sad just dont no what to do. Righ wen i need the p.o.s car aswell
(21-01-2013, 08:16 AM)bingham123456 Wrote: Nice one will try it in a min.
Before slamming the door the hinge in the middle take it off. This happened to my old hdi. I had no tools with me at the time and just had to slam the door. The hinge snapped and dinted my door.
I take it you've tried opening the door handle in case the catch is shut?
spray the catch with some deicer its just froze up did it on my car the other day little spray work it in Rolleyes
^ this.......
Yeah I had this the other day 10 mins with the heaters on job done
Just dont keep slamming it over and over again! This was a problem on my 1.4 when i broke it after i removed the checkstraps and moved the door hinges. Doesnt sound like the same problem though!
Figured it out finaly lol thanks for your help
It had froze solid i didnt have any de icer so used the next best thing........ A blow torch lmao
Heated it up n gave it a tap it worked like a charm lol.
Still needs propely sortin tho as the key is a pain to turn in the lock.
(23-01-2013, 11:44 AM)bingham123456 Wrote: Figured it out finaly lol thanks for your help
A bit of wd40 should sort that out spray it in the lock and work it in.
When i get some time will blast the lock with wd40
It's pretty common for this to happen, it had me scratching my head the first time it happened on mine....glad you got it sorted mate
Lol. I thought that would of been obvious in this weather
306s are a bit of a pig for this. Water must get down to the lock easily.
  Rear passenger side door won't open DonGonzo 0 2,259 19-10-2020, 10:25 PM
Last Post: DonGonzo
  Drivers door not opening from outside connorp 8 3,654 18-12-2015, 06:31 PM
Video Drivers door speaker aaron_one 11 5,844 01-10-2015, 07:35 PM
Last Post: aaron_one
