May be an obvious question, buuut..
For the people who have ground their LDA pin, what did you use to do it? Dremel type tool? Hmm
GT2052s DTurbo
OEM+ HDI Estate
Project thread
I used a Dan! tool.
/troll.
Captain Standard
Me too, but my Dan! tool is broken for 6 weeks
cwspellowe Wrote:Me too, but my Dan! tool is broken for 6 weeks
It's okay, the Dan! tool is made by Snap-On so has a lifetime warranty.
Captain Standard
I used a bench grinder lol and finished off with a dremel and sand paper.
Stage 2 XUD Sedan
strictly_derv Wrote:I used a bench grinder lol and finished off with a dremel and sand paper.
Really?! Surely the bench grinder was way too big? I really need to grind mine once the boost leak has been sorted..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Well it's a pretty hefty grind.....
[Image: IMAG0753.jpg]
ninja
Stage 2 XUD Sedan
Am I right in saying your pin is from a rover? You're right about it being hefty though, that looks really weak in the middle!
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Yep got it from a Rover. All the cars at the local scrappy have missing LDA pins now haha.
It does look weak but I doubt it will break and it's no biggie if it does TBH.
Stage 2 XUD Sedan
May invest in a dremel and get mine done.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Well worth doing, with this pin I've had to turn the fuel screw down nearly a full turn to clear the smoke at 26/7psi!
Stage 2 XUD Sedan
strictly_derv Wrote:Well worth doing, with this pin I've had to turn the fuel screw down nearly a full turn to clear the smoke at 26/7psi!
Your doing it all wrong then, your not supposed to turn anything down.............ever, too much smoke mean that you need more boost................not less fuel, that is backwards progress Tongue
Team Orange Engine Bay
Well because of my boost leak I was getting a load of smoke, so I am currently running with the pin at its steepest and its soo slow! But I was surprised at how much difference the pin alone can make, so can't wait to get it sorted.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
That is usually my philosophy but the wastegate spring must be weak and wont budge past 27psi.... the K04 will be my new boost producer soon though, no wastegate on that whistle
Stage 2 XUD Sedan
Fail post Wink
Was going to contribute to this..... but in actual fact mark is 100% correct Big Grin go find a bigger turbo
Yeah fk it, lorry turbo or gtfo
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
Dave Wrote:[Was going to contribute to this..... but in actual fact mark is 100% correct Big Grin go find a bigger turbo
He knows this, he is already on it with the K04 + welded wastegate, just needs to actually fit it to the bloody car :roll: lmao
You know it Mark :dance:
Stage 2 XUD Sedan
Make sure its smooth though! else it'll wear down the pin over time and slowly you'll loose the variation of your on/off boost...
