28-04-2012, 04:07 PM
been offered a t2 but the actuator has been broken off. worth replacing it or welding the wastegate shut?
![[Image: sig-1.jpg]](http://i170.photobucket.com/albums/u249/diggerspug306/sig-1.jpg)
SOLD
De-Wastgated T2?
![]() SOLD Dan! Wrote:Want me to blow this one up for you aswel?
28-04-2012, 04:32 PM
Just replace it. Could easily get an actuator in your pocket at a scrapyard
28-04-2012, 04:40 PM
The nipple broke off the actuator on mine so boost is controlled by fuel now like 4waydiablo's
Stage 2 XUD Sedan
28-04-2012, 05:23 PM
De wastegate it, it'll be fine if you're running mild fuel anyway so wont overboost.
28-04-2012, 09:39 PM
+1 for de-wastegated T2 at 22~28 Psi (I tweak fuel + LDA a lot).
29-04-2012, 09:31 AM
If your only on a 9mm pump DWG will be fine, the most mine would ever hit was 30psi.
29-04-2012, 09:35 AM
That's because no one jammed the gate shut, it'll blow open with high Exhaust Mani pressure...
29-04-2012, 10:22 AM
Ruan Wrote:That's because no one jammed the gate shut, it'll blow open with high Exhaust Mani pressure... Thats what was happening with my td04. The petrol wastegate just wasnt strong enough...now replaced with the spring from a 325tds actuator, much better ![]()
29-04-2012, 10:30 AM
anto Wrote:Ruan Wrote:That's because no one jammed the gate shut, it'll blow open with high Exhaust Mani pressure... Arc welder boost control FTW ![]()
29-04-2012, 12:09 PM
mark_airey Wrote:Arc welder boost control FTW This method got administered on all my turbos ![]() ![]()
29-04-2012, 12:49 PM
Dave Wrote:mark_airey Wrote:Arc welder boost control FTW well..............its easy, 1) with actuator still in place weld around wastegate arm, 2) remove actuator, 3) enjoy lots of boost ![]() It would be rude not to wouldn't it when its that easy ![]()
29-04-2012, 04:09 PM
just wondering guys, My mate decided to disconnect the hose from turbo housing to actuator, and plugged it. but actuator is still connected and cant hit over 22pis could the wastegate be opening with exhaust pressure?
Never give this much though CJ ![]()
29-04-2012, 04:23 PM
Yeh the spring is either weaker than the exhaust pressure on the flap and giving way, or there isnt enough fuel
29-04-2012, 04:28 PM
Dave Wrote:Yeh the spring is either weaker than the exhaust pressure on the flap and giving way, or there isnt enough fuel Oh yeah she smokes ![]() CJ ![]()
29-04-2012, 04:37 PM
Yeh thats more than likely whats happeneing, I know mine used to creep open whenever I was pushing 26+ psi.
29-04-2012, 04:41 PM
Dave Wrote:Yeh thats more than likely whats happeneing, I know mine used to creep open whenever I was pushing 26+ psi. Was just getting frustrated these last few weeks since got my love for my pug back and saw everyone boosting more than 22 and thinking hmmmm haha Trip to pick the welder up tomoz ![]() ![]()
29-04-2012, 05:37 PM
Sure a bit of exhaust putty could do the same job?
29-04-2012, 06:05 PM
silverzx Wrote:Sure a bit of exhaust putty could do the same job? Ive got some chemical metal somewhere lol suppose that could work lol ![]()
29-04-2012, 06:33 PM
CJ_Derv Wrote:silverzx Wrote:Sure a bit of exhaust putty could do the same job? Right on! Pikey XUD tuning ftw. :dance:
29-04-2012, 07:42 PM
Just in case welding it shut isn't pikey enough for you
29-04-2012, 08:25 PM
mark_airey Wrote:Just in case welding it shut isn't pikey enough for you Sigged!
29-04-2012, 08:35 PM
Sounds like mines creeping open as it won't go past 27psi...owell, i'm getting a bigger blower on there soon
Stage 2 XUD Sedan
29-04-2012, 08:37 PM
strictly_derv Wrote:Sounds like mines creeping open as it won't go past 27psi...owell, i'm getting a bigger blower on there soon 205 with beefy turbo, my dream car ![]()
30-04-2012, 08:20 AM
got welder on way to work lets see if its quiet over dinner whip the car up on Fork lift truck and away we go haha
