Gear oil change
Gear oil change
where is the gear drain and filler located on a 1995 1.9DT
is it a level fill system
Thanks
Drain is on bottom of tranny, can fill from top or from level plug, which is located in passenger side wheel arch, the larger of the bolts on the end...
[Image: sigi-2.png]
Would filling from level plug be enough oil?? or will i have to fill from the top?
Regards
Lol filling from the level plug would generally indicate that we its full to there, its level with where its meant to be Wink
[Image: sigi-2.png]
Cheers
is it best to replace the washers on the drain and filler bolts when changing the oil?
306 d turbo Wrote:Cheers
It's probably advised, but personally I've never changed them. If they leak its not a massive job to replace them.
  Gear change noise 306__xrdt 2 2,219 01-02-2013, 10:56 AM
Last Post: 306__xrdt
  Gearbox gear change? Ben 6 4,673 11-07-2012, 08:22 PM
Last Post: strictly_perv
