Gear change noise
Hi first gear and revers are a bit difficult to get in gear, i have made a short movie when i use clutch and changing gears is it normal with that much sound on gear linkage? and on the picture with red cirkle on it has the lever cracked?
Movie http://www.youtube.com/watch?v=4xq5G1jk6hw
[Image: img0286va.jpg]
Thank you Smile
[Image: 62941977.jpg]
That bit with the circle on it isn't that part of a spring mechanism ?? If it's hard to get into gear maybe it's the linkage worn or maybe the synchro ??
Problem solved Smile
  Gearbox gear change? Ben 6 5,111 11-07-2012, 08:22 PM
Last Post: strictly_perv
  Gear oil change 306 d turbo 6 4,224 25-04-2012, 09:36 PM
Last Post: Harky
