09-12-2018, 12:22 AM
hey guys
I am having some problems and need some help.
I have a 1994 306 1.8l
my visual observations are-
transmission leaking but not sure from where.
there is some fluid on what i believe is the ATF cooler (the round thing with 2 tubes out the top) and there is a lot of wetness with a little drip at the bottom of the trans.
Also, I noticed the throttle cable or kickdown cable (not sure what you call it) where it enters the transmission there is a little clip that is broken and the outer art of the cable can be pulled out of the transmission.
driving observations-
reverse gear was not engaging and took a rev to KICK in.
then, last night all my gears seems to be shot. just did nothing.
but in the morning the trans was working again.
any advice?
any advice?
