Threads: 101
Car Model/Spec: 306HDi 90 LX
Hi all,
I fancy putting some led strips on the bottom of the doors for night time stepping out.
is there likely to be a switched power supply in the door harness that only comes live when the door is opened that I could connect to?
(I don't have my Haynes handy).
It goes, it stops (as reqd).
Hate Housework!
Threads: 25
Car Model/Spec: 1999 Rallye || 1999 HDi
Given 3 thank(s) in 3 post(s)
I can't give you an exact answer because I don't know but surely there's a switch somewhere that tells the standard interior lights to turn on and then fade out when doors open?
1999 - Black Rallye A/C
2002 - Silver 206 1.4 HDi LX
Threads: 101
that's what I had in mind. thanks.
Hate Housework!
Threads: 465
114
Car Model/Spec: Vauxhall
Ph1+early Ph2 has door pin switches
later Ph2+Ph3 has a door closed switch in the door lock
Threads: 101
ah-ha! most excellent information, thank you!
Hate Housework!
