ph3 door power - Printable Version
+--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23)
+--- Thread: ph3 door power (/showthread.php?tid=37042)
ph3 door power - Magenta Sunset - 14-09-2018
Hi all,
I fancy putting some led strips on the bottom of the doors for night time stepping out.
is there likely to be a switched power supply in the door harness that only comes live when the door is opened that I could connect to?
(I don't have my Haynes handy).
RE: ph3 door power - wainwrightj - 14-09-2018
I can't give you an exact answer because I don't know but surely there's a switch somewhere that tells the standard interior lights to turn on and then fade out when doors open?
RE: ph3 door power - Magenta Sunset - 14-09-2018
that's what I had in mind. thanks.
(14-09-2018, 09:27 AM)Magenta Sunset Wrote: that's what I had in mind. thanks.
You'll have to figure out which wire you need but I can't see it being all that difficult, sorry I wasn't much help but good luck!
RE: ph3 door power - Magenta Sunset - 16-09-2018
ThumbsUp
RE: ph3 door power - cully - 16-09-2018
Ph1+early Ph2 has door pin switches
later Ph2+Ph3 has a door closed switch in the door lock
ah-ha! most excellent information, thank you!
