replacing damaged oil seal
Guide: replacing damaged oil seal
quick guide on how to get out and replacing a oil seal on a crank
locate oil leak strip down to expose damaged seal
drill small hole in seal casing maybe 2 at 180degs
insert screw and slowly screw into the seal which should start to press the seal out of the housing if this dont work add a second screw at 180 degrees and use both to press seal out
refit new seal buy tapping into position
check all faces and reasemble
GTI6 Info
Great stuff. Thanks Cully Smile
  Replacing Speedo Housing Gearbox Oil Seal Grant 4 5,635 21-08-2013, 10:32 AM
Last Post: Grant
