Threads: 66
Car Model/Spec: 306 Estate - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
Need to know the thread sizes for a gt15 chra and the size on the block for the high pressure turbo feed.
Still Living For The 306
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Info in my project thread somewhere
Threads: 66
Got to the chra is m10x1.0 so far.
Any idea on hdi block size tho?
M12x1.25 or M14x1.25 - try a wheel bolt in it lol - it's the same from memory. Might be an M14 though.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
Threads: 66
Found an xud is apparently m16x1.5. Spose block feeds deffo easiest to check from underneath
Threads: 42
28
sounds about right, the oil pressure warning light is m16x1.5 too.
Threads: 66
Adapters are only £4 a pop so not exactly much to lose. Just gotta decide on pipe size then. Either an-4 or an-8 finding most garret AN kits are an-4 so guessing thats the kiddy. Prob work better over the distance too to reduce pressure drop
