Oil feed sizes - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Oil feed sizes (/showthread.php?tid=36014) |
Oil feed sizes - dr_jekyll - 15-06-2017 Need to know the thread sizes for a gt15 chra and the size on the block for the high pressure turbo feed. Sent from my SM-G920F using Tapatalk RE: Oil feed sizes - fatlapit - 16-06-2017 garrett website?? Oil feed sizes - zx_volcane - 16-06-2017 Info in my project thread somewhere Sent from my iPhone using Tapatalk Pro RE: Oil feed sizes - dr_jekyll - 16-06-2017 Got to the chra is m10x1.0 so far. Any idea on hdi block size tho? Sent from my SM-G920F using Tapatalk RE: Oil feed sizes - Ruan - 16-06-2017 M12x1.25 or M14x1.25 - try a wheel bolt in it lol - it's the same from memory. Might be an M14 though. RE: Oil feed sizes - dr_jekyll - 16-06-2017 Found an xud is apparently m16x1.5. Spose block feeds deffo easiest to check from underneath Sent from my SM-G920F using Tapatalk RE: Oil feed sizes - welshpug - 16-06-2017 sounds about right, the oil pressure warning light is m16x1.5 too. RE: Oil feed sizes - dr_jekyll - 16-06-2017 Adapters are only £4 a pop so not exactly much to lose. Just gotta decide on pipe size then. Either an-4 or an-8 finding most garret AN kits are an-4 so guessing thats the kiddy. Prob work better over the distance too to reduce pressure drop Sent from my SM-G920F using Tapatalk |
