22-09-2015, 02:06 PM
XUD RR results *THE BIBLE*
22-09-2015, 05:34 PM
It had a welded Westgate on it, it was you old turbo piggy that I had then sold atlas
22-09-2015, 06:05 PM
Sorry, a welded WG on a GT20?!
![]() Did we not learn ages ago that this is a bad idea? Welding and fabrication projects undertaken, contact me for more information.
22-09-2015, 06:28 PM
Haha!
Yeah, recall the lad with the zombie 306 who first tried a GT2056 iirc with a solid wastegate and promptly spat the turbo out the exhaust! Wishes for more power...
22-09-2015, 10:31 PM
C S Pellow iirc
23-09-2015, 11:30 AM
Epic little turbos. Shame theyre made of cheese
3 x Peugeot owner.
1996 106. 1996 306 D Turbo S. 1994 Mercedes Benz 320E. 1997 306 GLX. Subscribe! - https://www.youtube.com/user/TheADKJD/videos
23-09-2015, 11:35 AM
If they're kept at a sensible boost level, they'll last.. what did you expect at nearly 40 psi lol
23-09-2015, 11:41 AM
(23-09-2015, 11:35 AM)Midnightclub Wrote: If they're kept at a sensible boost level, they'll last.. what did you expect at nearly 40 psi lol Amen Wishes for more power...
23-09-2015, 05:35 PM
Soz forum
3 x Peugeot owner.
23-09-2015, 06:00 PM
Meh, it's your loss. Just seems kind of pointless when it'd still be running and making the same power if you'd done it properly.
23-09-2015, 06:11 PM
(23-09-2015, 06:00 PM)Jonny81191 Wrote: Meh, it's your loss. Just seems kind of pointless when it'd still be running and making the same power if you'd done it properly. Hmmm. Was thinking that with a fmic and at say 27/28psi you wouldnt need the WMI to bring temps down at all either. Good effort though lad! Just its not a honest figure in my book as you can only make that figure with that setup once or twice before it will crap itself Wishes for more power...
28-09-2015, 04:31 PM
Cleaned, please keep on topic chaps, feel free to abuse each other on FB
05-01-2016, 05:29 PM
16-01-2016, 08:16 PM
I'll add mine, from the 205 derv missile.
176.7hp, 247lb/ft - GT2056s @ 23/24psi, FMIC, 9mm Gov and LDA , 2.5" downpipe and exhaust, lightened flywheel, ported head, hdi rods, ARPs.
28-05-2016, 01:04 PM
(05-01-2016, 05:29 PM)niciou Wrote: Hello everyone passage au banc : 205 td 2.1 8 s , turbo td04l 15t , 30 psi puissance : 229.4 cv a 4417 tr/min couple : 431. NM (28-05-2016, 01:04 PM)niciou Wrote:(05-01-2016, 05:29 PM)niciou Wrote: Hello everyone test puissance en video: https://www.youtube.com/watch?v=XmHHOHt3...e=youtu.be https://www.youtube.com/watch?v=W0aciRaw...e=youtu.be (28-05-2016, 02:01 PM)niciou Wrote:(28-05-2016, 01:04 PM)niciou Wrote:(05-01-2016, 05:29 PM)niciou Wrote: Hello everyone
Hi everybody
Passage to the bench ZX td Turbo t2-t25 pressure 1.6 bar Fmic HDI box Pump 11mm 169 cv 326 N-M
21-01-2017, 02:03 PM
(21-01-2017, 01:40 PM)niciou Wrote: Salut a tous What power did it make then??
21-01-2017, 02:09 PM
(21-01-2017, 02:03 PM)bashbarnard Wrote:(21-01-2017, 01:40 PM)niciou Wrote: Salut a tous Sorry i try to put the sheet of the passage to the bench i can not get there ![]() 169 cv 326 N-M
21-01-2017, 04:01 PM
Not a bad result that for an old turbo which is essentially bolt on job
13-03-2017, 10:39 AM
(21-01-2017, 01:40 PM)niciou Wrote: Hi everybody
25-09-2017, 08:13 PM
Thread tidied up. Tom (zx_volcane) is right. Thread is for rr figures.
21-10-2017, 08:23 PM
21-10-2017, 09:18 PM
In many ways
22-10-2017, 12:42 PM
Good result man. Must go like a rocket in that thing
25-10-2017, 07:43 PM
A great result, just hoping it lasts. Mine did 170 horse at a safe 20 psi. Don't really want to risk much more boost on mine as it's fast with 20 psi. Yours must be a right monster. Well done.
Hoping to add our 206DT to this list soon, got to sort a cooling fan and book in with a local company but I'm expecting (hoping for) 160+bhp from butt-dyno measurements from-:
Square-port D8A stock Xantia engine mileage unknown, K14 @ 25psi, Xantia FMIC, Mix of Xantia and home fabricated hard pipes, Open turbo elbow currently but may go to 2.25" straight pipe, 9mm Bosch gov'd and LDA ground 'til I got scared it'd snap, 206 GTi180 flywheel, Running 100% Sunflower oil Will report back when I actually have paperwork, even if it's embarrassing as feck! EDIT- well I spoke too soon, K14 is dead, oversped the feck out of it (27psi-ish @ about 4700rpm with small boost leak from intake mani') and blew the turbine apart! Soon to be replaced with a GT2052V along with better manifold sealing. Hopefully be a better match for the kind of power we're after & if I get the VNT actuation just right should be a bit easier on the standard head bolts. |
Dyno Results inside! (and questions) | Jimbo | 30 | 12,896 |
13-06-2014, 10:22 AM Last Post: zx_volcane |
My dyno results | Mac22 | 8 | 3,074 |
12-06-2014, 03:26 PM Last Post: Mac22 |
Bosch, T2, stage one, dyno results? | Mitch | 22 | 14,487 |
14-04-2013, 08:36 AM Last Post: Mitch |
