Dash lights
Hi!
Today I noticed that only 1 dash light is not working. It is for low beam (green one). Lights work when they should.
All other lights seem to work.
How hard it is to replace single dash bulb, because, I probably will take dash out anyway to fix odometer screen.
Very easy, the bulbs just twist in the back of the dash cluster once removed.
easy enough, lot easier if you remove the steering wheel first Smile
Thank you! Bulbs are regular T5?
Sent from my BLASTER using Tapatalk
(19-10-2016, 03:10 PM)Dreijers Wrote: Thank you! Bulbs are regular T5?
285 or T5 wedge as you say
Update on this - light came back on without doing anything.
Another thing that I can say fixed itself.
  Dash lights not on?!help!! Matt_adams 1 2,199 18-05-2016, 07:41 AM
Last Post: aggyj17
  Instrument lights, dash lights not working boggs 3 4,732 26-01-2016, 09:34 PM
Last Post: DeeTurbo
  Ford KA 2012 dash lights? ginge191 3 7,010 21-12-2015, 07:11 PM
Last Post: daddyfixit
