eBay: XSI + Turbo + Water Meth
http://www.ebay.co.uk/itm/1997-PEUGEOT- ... 2456634268
interesting this...
That engine bay looks really odd? Manifold weirdness
4wayDildo Wrote:That engine bay looks really odd? Manifold weirdness
thats what i thought - i think because the water meth system is "in the way"
You realise its a blown 8v motor yeh? Tongue
[Image: sigi-2.png]
darrenjlobb Wrote:You realise its a blown 8v motor yeh? Tongue
"blown" ... a non runnner is all i read through it
but that setup with a GTI head = winnnn?!?
Don't think the heads align properly IIRC
Midnightclub Wrote:Don't think the heads align properly IIRC
but the GTI heads fit onto a 1.8 bottom fine :?
..french
Blown as in charged.
Fanimolds are completely different iirc, won't work.
This was more popular "back int' day" when 306s were worth more than loose change and GTi6 XU engines held values of £800+ ancilliaries.
It was a cheap conversion from a 406 I think, 150bhp standard? Easily tweaked to 220bhp from memory. 8v head as mentioned, however not a bad car if/when it works. I imagine those vacuum hoses and complex array of piping would eventually piss off your average DIY spanner monkey however, when the same power can be made more reliably from a common VAG 20V lump.
[Image: Sig500x130.png]
