Threads: 101
Car Model/Spec: 306HDi 90 LX
hi all,
has this been covered in here?
looking for a good quality set for when I get the beam refurbed & fitted.
if you have supplier, part num, & apprx price that'd be ace!
It goes, it stops (as reqd).
Hate Housework!
Threads: 58
febi and febi only
Threads: 101
(24-06-2016, 09:26 PM)Stef205 Wrote: febi and febi only
fank you!
Hate Housework!
Threads: 102
18
I am also using febi beam mounts, the rear of the car felt excellent on a recent sprint day.
Threads: 101
where's the 'best place to shop'?
Hate Housework!
Threads: 213
Car Model/Spec: HDI
I find Misterauto the cheapest and delivers very quickly, bought loads from them recently.
Threads: 101
(25-06-2016, 04:30 PM)MY95 Wrote: I find Misterauto the cheapest and delivers very quickly, bought loads from them recently.
thank you
Hate Housework!
No idea where 'misterauto' appeared from but I've also used them and can't complain.
Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
I was the same. I had never heard of them but they were fantastic. In fact I shall also be getting more stuff from them including rear beam mounts. Their site also has good photos and descriptions of stuff which is nice.
Threads: 101
found some reduced price febi's on fleabay so bought them. (aceparts_uk)
Hate Housework!
Threads: 50
Car Model/Spec: 306 HDI Dturbo
Another vote for Febi - fitted some last year and they were spot on.
Threads: 102
18
(02-07-2016, 08:47 AM)Magenta Sunset Wrote: found some reduced price febi's on fleabay so bought them. (aceparts_uk)
That could well have been who mine were from off the bay of E. They feel very nice along with a rebuilt rear axle.
Threads: 101
(02-07-2016, 06:39 PM)RetroPug Wrote: (02-07-2016, 08:47 AM)Magenta Sunset Wrote: found some reduced price febi's on fleabay so bought them. (aceparts_uk)
am having to move to 'plan-b' asap.
sand-blasted used beam (informed it was good) repainted with spray hammer, & fitted in time for end of month hols.
Hate Housework!
Threads: 102
18
The axle is easy enough to swap, a couple of things that will hold you up if you are not prepared:
You can either disconnect the calipers and then reconnect them, or it is possible to remove the rear beam without disconnecting the rear brake lines from the caliper, but difficult to get the beam out between the lines. If you do disconnect them, unions can be difficult to undo, lines can twist etc. so make sure you are able to deal with this if it happens.
The beam mounts through the floor require a deep 16mm socket, which is an uncommon size and not in a lot of socket sets, so check that you have one beforehand. If you need one and can't find one in a shop eh. Halfords, a 16mm spark plug socket is an option.
Threads: 101
(02-07-2016, 08:45 PM)RetroPug Wrote: The axle is easy enough to swap, a couple of things that will hold you up if you are not prepared:
cheers, but i'll speak to a 'man that can'
Hate Housework!
Threads: 102
18
I suppose making someone else do it is being fairly well prepared.
Threads: 15
Car Model/Spec: XSi
03-07-2016, 10:02 AM
(This post was last modified: 03-07-2016, 10:02 AM by adam b.)
16mm deep socket is in most sets - it's the same as the spark plug size
Edit: read all that post doh
P1 XSi track car
2.4 LWB T4
Threads: 101
(02-07-2016, 11:33 PM)RetroPug Wrote: I suppose making someone else do it is being fairly well prepared.
man that can has more tools, space, and practice than I can throw hot tea at
Hate Housework!
Threads: 0
Car Model/Spec: Protest R26 Liquid yellow
ECP do Febi reasonably cheaply, especially with discounts..
Threads: 42
28
most non budget brands will be fine, using o.e on my car though.
Threads: 101
is ti work a quick flash of rattle-can b4 fitting?
Hate Housework!
Threads: 7
Car Model/Spec: 306 2.0 HDi
(24-06-2016, 09:19 PM)Magenta Sunset Wrote: hi all,
How much are you paying for the beam to be refurbished? If you don't mind me asking?
Threads: 101
20-09-2016, 08:06 PM
(This post was last modified: 20-09-2016, 08:07 PM by Magenta Sunset.)
I got some Febi ones from Aceparts_uk on Ebay
DocScreen1.pdf (Size: 203.68 KB / Downloads: 193)
Hate Housework!
