Things left to do before fcs
So for me on the estate its cambelt, service, axle lower, dront struts on map.
Then service lus, p bushs and detial
Just wondered what everyone else needed to do before as well
seam wlded sub frame
heater matrix
ds2500 pads
spare wheel
track tyres on
bolt check
5.1 fluid
fire extinguisher
clean
balance bodies
wiring
engine mounts
and much much more!
206...service next week as its due in 400miles.
306...finish off cooling aids....
"airbox"
Service engine
Servive brakes
Bolt n general check
Fit undertray
Meth injection
Wash and first wax of the year.
Maybe tidy up inside a bit
Passenger side track rod end, airbag replaced with glovebox and a damn good clean
Fit oil cooler so can stay out longer on track / reduce risk of fking the engine
Fit thermal intake gasket without a vacuum leak
Sort out front tyre as it's taken some abuse
Gearbox oil
Fix abs sensor issue
[Image: mcetg0.png]
Things left to do before fcs...
oil change
fit track disc/pads
balance some wheels
clean the girl
general nut n bolt check
GTI6 Info
Front left and right trackrods, do want to sort the front bumper as the skin has come away on the passanger side.
/Toseland
Blend in the paint on the rear arches after I did such a shit job of rolling them on the track side.
clean inside and out.
track front wheels
nuts and bolts check
(21-05-2016, 08:02 AM)cully Wrote: Things left to do before fcs...
oil change
fit track disc/pads
balance some wheels
clean the girl
GTI6 Info
Swap tyres front to rear, fill with fuel*, check new tent came with pegs, find BBQ
*I'm probably going to have to fill with fuel at least 4 times before FCS if not 5 or 6 times. Smiles per gallon FTW.
Sort constant heat problem
Idle / revving problem
Adjust suspension to be stiffer
Fix knock on front left
Fix ABS system
Change wheels / tyres
Full detail
And more depending what parts I can get hold of lol
Not a huge amount tbh.
Try and find/fix boost leak (well it sounds like it has one)
Maybe fit powerflex bushes on suspension arms
Give it a decent clean
(20-05-2016, 09:41 PM)bashbarnard Wrote: So for me on the estate its cambelt, service, axle lower, dront struts on map.
so mines done apart from map and clean now done it all yesterday
nothing at all, Going to Bournemouth wheels which for me is much better
Finish the strut brace and fit
Align exhaust
Clean a lot
Done
(22-05-2016, 01:09 PM)Frosty Wrote: Maybe fit powerflex bushes on suspension arms
Remember to do your tracking after, because they change the geometry slightly
Clean and give a full detailing... that's all
(23-05-2016, 07:07 AM)ginge191 Wrote: Buy less of a hairdresser's car... that's all
EFA
/Toseland
(23-05-2016, 12:30 AM)Matt Wrote: Finish the strut brace and fit
Align exhaust
Clean a lot
Done
We having a cleaning day?! Doing mine on the Thursday, you about?
EFA
The megane is no 'cc' model!
Will do cheers
change ex cam seal
put fuel in see how long gearbox lasts for
Loads I want to do, but realistically >
Get exhasut downpipe sorted with a flexi.
Get a good wash and polish on the go.
Hope it doesn't blow up.
Would love to get some tuning in too, in proper need of setting up since the rebuild.
Align exhaust
Clean a lot
Done
EFA
I'm game, I've got the whole weekend of so will see what I am working Thursday Smile
(20-05-2016, 09:46 PM)Piggy Wrote: 206...service next week as its due in 400miles.
"airbox"
Service engine
Service brakes
Fit undertray
Meth injection
Polish up wheel bolts
Finish off oil cooler
Rear camera mount
Fit battery fuses
Internal central camera mount
I like adding to lists and immediately crossing things out... Feeling of accomplishment Rofl
My list now has added to it:
Get wheel bearing changed
Fit new pads and discs at the front
Add more cable ties
Top up coolant
Top up pas fluid
I now need to change the throttle cable too
(25-05-2016, 07:46 AM)rocker8742 Wrote: I now need to change the throttle cable too
I will prob change mine too because my throttle cable is soooooo long it looks naff. Slightly shorter of the xsi 16v so will get one of those me thinks
Mine just snapped this morning lol
(24-05-2016, 10:01 PM)Dum-Dum Wrote: My list now has added to it:
Add more cable ties
Top up coolant
Top up pas fluid
And now add to that new calipers both sides as it turns out that at least half the pistons on the nearside are seized, one can't be budged and I've been told if the nearside is like that then the drivers is probably not far behind so might as well replace both.
Anything else goes wrong and I'm gonna have to sell my track time.
How about just reduce your alcohol budget so you'll be sober enough to use the tracktime? Tongue
