Push Vs Pull Clutch
Push Vs Pull Clutch
What are the advantages of converting the HDi gearbox/clutch then?
I've acquired a taller FD/output shaft which I plan on shoving into an HDi box. Whilst at it, I was considering this clutch conversion too seeing as I've all the bits in one of my garages.
But, why? Better selection of clutches for Stage 2? Easier clutch pedal?
Someone tell me!
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Torque holding is the only advantage of the pull type that I'm aware of. Clutch pedal will be light and smooth with either clutch if you use new cable and fork bushes when changing it.
I converted to pull clutch, higher clamping force, lighter flywheel (by 4kg) and got rid of my auto adjuster. The clutch is light as.
Also more options for uprated clutches when you use a 6 flywheel
this on the HDi?
/Toseland
Yes
  Possible crank pull Steve1990 8 4,147 09-02-2015, 07:12 PM
Last Post: Steve1990
  EGR Push in type blank? pugdan95 5 3,625 09-01-2015, 07:21 PM
Last Post: doski
