Threads: 214
Car Model/Spec: 306 hdi meridian
06-03-2016, 09:55 AM
(This post was last modified: 20-03-2016, 08:05 PM by Welshy_Pete.)
Hello I noticed on my 306 hdi sometimes when starting the car near the mileage clock it will show like a alarm clock or timer thing. The rev and speed counter both move up from 0 to the same place near max higher up then go back down to normal?
Just seeing what this means?
Thanks
Threads: 101
Car Model/Spec: 306HDi 90 LX
mine does that too sometimes. I take the view the battery is a bit low.
got myself a dash solar panel to compensate a little.
It goes, it stops (as reqd).
Hate Housework!
Threads: 214
I've checked the battery while engine running and off the battery 13v+ when off when on 15v+ so the battery good.
I've cleaned the connections on the battery, 2 earth's below the battery also earth near driver front headlamp.
There anymore earths or connections to try and clean.
Threads: 214
Ive sprayed wd40 everywhere the problem cleared up now thanks.
Threads: 42
28
shouldn't have 15+ on the battery!!! you need a new rectifier on the back of the alternator
