New wheels. Another one
Right so specs are 16x7 et 20 or et 25. Et20 will need 3mmish spacers and et 25 will need 10mm. Am I right?
I can either go 15" or 16" but I am undecided. I want them too sit nice and tight to the outer arch, but don't want to have to do any arch work
Am I right about the spacers? If so would the et 25 with 10mm spacers likely scrub? I'm quite low
Depends on tyre size too don't forget.
Imo, et15 is much better look. Et18 standard sits quite far in...
I'm running et-2 with 15x6 with 195s...lowered 40mm. Slightly rolled arches. So plenty of scope
Thanks given by: Matt
I'd probably run 195/45 or 195/50, I'm more than likely going to run the et25 with a 10mm spacer
That sounds fine then tbh
Right so it will be 15x7 et 20 with a 10mm spacer running 195/45 feel these will fit perfect and no need for arch rolling.
Just got to find the £350 now ?Rofl
Cheers for the help
if you can squeeze up to '50 profile tyres you can get PS3s for 46 each from black circles
/Toseland
Depends on the width of the wheel.
ET is only relevant when you know that.
He has put the width of the wheel!
The choice is et 30 with 15x7
Or et 20 15x8
I got mixed up. Which will fit in the arch better? I'd prefer the run the 8j with 5mm spacers, but I really don't want to have to start arch rolling it all
15x8 and I would have said you'll need to roll arches
