New wheels. Another one - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: New wheels. Another one (/showthread.php?tid=33394) |
New wheels. Another one - Matt - 01-03-2016 Right so specs are 16x7 et 20 or et 25. Et20 will need 3mmish spacers and et 25 will need 10mm. Am I right? I can either go 15" or 16" but I am undecided. I want them too sit nice and tight to the outer arch, but don't want to have to do any arch work Am I right about the spacers? If so would the et 25 with 10mm spacers likely scrub? I'm quite low RE: New wheels. Another one - Piggy - 01-03-2016 Depends on tyre size too don't forget. Imo, et15 is much better look. Et18 standard sits quite far in... I'm running et-2 with 15x6 with 195s...lowered 40mm. Slightly rolled arches. So plenty of scope RE: New wheels. Another one - Matt - 01-03-2016 I'd probably run 195/45 or 195/50, I'm more than likely going to run the et25 with a 10mm spacer RE: New wheels. Another one - Piggy - 01-03-2016 That sounds fine then tbh RE: New wheels. Another one - Matt - 01-03-2016 Right so it will be 15x7 et 20 with a 10mm spacer running 195/45 feel these will fit perfect and no need for arch rolling. Just got to find the £350 now ? Cheers for the help RE: New wheels. Another one - toseland - 02-03-2016 if you can squeeze up to '50 profile tyres you can get PS3s for 46 each from black circles RE: New wheels. Another one - welshpug - 02-03-2016 Depends on the width of the wheel. ET is only relevant when you know that. RE: New wheels. Another one - Piggy - 02-03-2016 He has put the width of the wheel! RE: New wheels. Another one - Matt - 03-03-2016 The choice is et 30 with 15x7 Or et 20 15x8 I got mixed up. Which will fit in the arch better? I'd prefer the run the 8j with 5mm spacers, but I really don't want to have to start arch rolling it all RE: New wheels. Another one - Piggy - 03-03-2016 15x8 and I would have said you'll need to roll arches |
