306 xsi vibrating harshly when pulling off
Could it be a faulty seal on your slave cylinder?
(26-01-2016, 09:06 PM)Redordead89 Wrote: Could it be a faulty seal on your slave cylinder?
306s are all cable operated, no slave cylinder. Smile
Does your coolant level drop? If so check around the stat housing and temp sensor for leaks, coolant could be leaking onto the clutch...
Yeah coolant does drop but I'm having a nightmare locating leak
Lol
  front end needs pulling straight :( toyo16 24 4,888 08-02-2014, 05:13 PM
Last Post: toyo16
