just another gti6
just another gti6
#61
Yeah man cheers ratty. The car is on a diet atm. Fitting different seats a load of weight has been removed. Carbon door cards and footwells. Converted the doors to manual winders and mirrors. Put the fuel pressure up and got a new pro alloy inter cooler also.
What you hoping to get it down to weight wise?
Hopefully near 1 ton but from the bulkhead back its 100 percent stripped ok ive still got a headlining. So my next plan is radical but if done well it should help no end without weakening the xar
Carbon panels?
nice looking car , good job on motor
Cheers twangy
Spaceframe front end ratty
reet guys
small update
so iv`e had the spoox box in now for about 500 track miles and about 800 road miles. All I can say is what an improvement in grip braking and overall acceleration. The 3j diff has been amazing cant believe how much difference specifically in the braking it has over the atb.
had a couple of issues at croft. one was a broken oil cooler and a broken manifold.
So now with all that repaired and a quick road test all seems well and ready for maore mapping at efi on Thursday ready for fcs then either snett or cadwell in august.
Heres a quick spec:
L44 PTT
FROG
Engine:
Fully rebuilt 2046cc
Rebored, decked and honed
87mm low compression pistons
Forged conrods
Balanced and lightened crank
ACL race bearings
Lynx power head bolts
Skimmed head with oversized inlet valves
Ports matched to inlet and exhaust manifold
Stainless steel tubular manifold
Garret gtx2867 turbocharger
650cc Asnu injectors
omex 600 ecu
Omex wiring harness
Turbosmart compgate 40mm external wastegate
Turbosmart 50mm dump valve
Tubosmart FPR 1200 fuel pressure regulator
Turbosmart in car boost controller
3" turbo back stainless steel exhaust using flowmaster silencers
Nissan 200sx aluminium race radiator
Mitsubishi evo 6 race intercooler
Fabricated aluminium 2.5” boost pipes
2.5 bar map sensor
Pipercross airfilter
Vibra technics race engine mounts
Mocal oil system with oil cooler and sandwich plate
royal purple racing oil
Coolant pipes fabricated
Exhaust system fabricated
Exhaust system heat lagged
Boost circuit fabricated
Bulkhead heat shield
Gearbox
Helix paddle race clutch
Lightened and balanced flywheel
Spoox time attack spec box
3J diff
Brakes
Front Tarox 330 10 pots
Rear Standard callipers with wavy discs and ds2500 pads
In car brake bias valve
steel Braided flexi hoses
New copper piping though out
Millers dot 5 racing fluid
Wheels and suspension
OZ Leggenda 17" alloys AD08r for wet and road use
OZ super legger 17” alloys semi slicks
BC Racing coil overs with Baker BM camber adjustable top mounts on the front
Peugeot sport 24mm torsion bars and 30mm anti-roll bar beam
negative camber rear trailing arms bc racing shocks
Vibra technics p bushes
Solid rear axle mounts
lowered all round and corner weighted
Interior
Sparco pro adv
TRS 3" 4 point harnesse
omp steering wheel
Quick release wheel boss
stack gauges for boost, exhaust temp and afr
Swirl pot and uprated fuel pumps and fuel pressure regulator in boot area
battery located to boot area
wiring of the whole car has been thinned
omp 6 point cage
harness bar
Fire extinguishes fitted in the cab
Exterior
front bumper modified for better cooling
Fibre glass bonnet with vents
carbon wing mirrors
hopefully over winter a new intercooler should be here along with water meth.
[Image: 20170624_163712.jpg]
[Image: 20170624_163825.jpg]
[Image: 20170621_185153.jpg]
[Image: received_10158675230215577.jpeg]
[Image: received_10158675229800577.jpeg]
[Image: 20170522_204930.jpg]
[Image: 20170522_204922.jpg]
[Image: 20170520_154041.jpg]
[Image: 20170520_154025.jpg]
[Image: IMG_1495054042547.jpg]
if you look closely there is a crack in the oil cooler in the blue circle that ended my day early at croft
flash the tig over it that all i did with mine.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
