306 rallye trackday project
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
This is probably one of my favourite projects on the forum as the CF is all homebrew moulds. Can't wait to see this in action.
62k Diablo Phase 1 Gti-6:
Project Thread
(27-10-2015, 12:27 PM)RetroPug Wrote: This is probably one of my favourite projects on the forum as the CF is all homebrew moulds. Can't wait to see this in action.
thanks very much , will let you no when its out on track , and hopefully will do some club days next year , theres still a bit to do before that eg mapping  , and finishing paintwork and graphics , also after cams  ,but will let you no as soon as out on track ,thanks wayne
Airbox looks awesome, reminds me quite a bit of the airbox on the maxi rally car
(27-10-2015, 01:05 PM)Midnightclub Wrote: Airbox looks awesome, reminds me quite a bit of the airbox on the maxi rally car
thanks mate
those things are going to suck better than a turbo charged hoover,
the air box look epic, good job. Just think of all that lovly cold air being pushed through the gap straight into your jenvys Smile
Are you running unfiltered? or will your at least put a pre screen on?
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
(27-10-2015, 01:09 PM)insomaniac45 Wrote: those things are going to suck better than a turbo charged hoover,
cheers mate , yes will be running a filter  just haven't had time to order or fit , should get plenty of cold air to jenveys like you say
how do you get the CF to cure?
Hate Housework!
(27-10-2015, 05:19 PM)Magenta Sunset Wrote: how do you get the CF to cure?
hi m8 , its basically like doing fibre glassing , with resin
only difference to CF to FG is your using Carbon Fiber matt as the medium Smile
its used alot in the RC plane world Smile
Not always Grumpy!!
reminds me.
must make a start on dash binnacle sometime - - -
Hate Housework!
finished air box and made and fitted filter as ramair supplied me with  filter caging and filter foam for a bargain price of £15  next day delivery , and best of all enough to make a spare 1 , , total bargain
finally got round to  priming and painting carbon fibre door and lower quarter  were rub strips removed , and started fitting graphics
carbon  n/s door all now fitted up , and made a start on dropping front cross member as  am seam welding it  so removed and started to grind down ready for welding
Can you post photos as you do the seam welding? I want to do it on mine when I get my welder sorted
Look at my project thread Dan, I did it 5 years ago now.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Nice build, I'll be following!
seam welded subframe all painted and ready for refitting , so will refit over weekend
while i had subframe stripped off, took some photos of rosejointed gear linkage that was made  up
big plans for new year for the 306 ,as have started collecting a few bits over the last month , engine wise have kent cams pt81 cams and vernier pulley ,to go in engine ,will get pockets put in pistons , then strate for mapping , have new spal fan , and new race loom getting made , also after vts rack , so quite a bit to get on with
Get my pm about the airbox, Wayne?
P1 XSi track car
2.4 LWB T4
Wow that airbox is awesome. Cracking project
(29-12-2015, 10:47 PM)adam b Wrote: Get my pm about the airbox, Wayne?
hi adam , yes did get pm about airbox  ,but would not let reply , did try and message on the gti forum , i am going to try and make a load of item in new year mate , so will keep you posted
(29-12-2015, 10:56 PM)Blandy Wrote: Wow that airbox is awesome. Cracking project
thank mate
Custom work is insane! Fantastic.
Thumbs Up
(30-12-2015, 09:40 AM)Iaitoo Wrote: Custom work is insane! Fantastic.
thanks very much
started stripping front end of car ,, as need engine out ready to go to engine builders ,  and why engine getting done can make
new light weight  race car loom and freshen up front end
    [took delivery of pt81 kent cams and vernier pulleys , ready for engine wich will be getting built in next month
Read the thread from the beginning and I have to say there's some awesome fabrication gone on in this build,well done!
Thumbs Up
(10-01-2016, 10:29 PM)roland rat Wrote: Read the thread from the beginning and I have to say there's some awesome fabrication gone on in this build,well done!
cheers  mate
Looking really good mate
What size cooler do you run Ive had to move up to a 19 row as the 16 wasn't really up to it.
[Image: Cn91r40h.jpg]
(12-01-2016, 12:57 AM)7057sam Wrote: Looking really good mate
sam  ,only using 13 row cooler on car  , had no problems yet , but am on remote filter so does hold bit more oil and big rad for extra cooling  ,
  Matts £200 Cherry Rallye shell rebuild & tidy up project. Xsara goodies landed! Matt-Rallye 70 63,678 07-03-2017, 12:58 PM
Last Post: Matt-Rallye
  Matts rallye project. operation derust Matt 630 480,182 23-06-2016, 06:41 PM
Last Post: Frosty
  The toy, 306GTI trackday racer. *Dial-up warning: Picture heavy* Janne L 142 88,159 11-03-2016, 07:58 AM
Last Post: Janne L
