Threads: 3
hi i have a phase 3 2000 306 xsi that needs a new n/s lower arm im having trouble finding one .
i have only managed to find a phase 1 and a phase 3 arm the site said it will fit 10/1998 TO 06/2002 ALL MODELS
will this fit my car cheers
Threads: 130
82
Car Model/Spec: 106 GO-NAD
afaik they are all the same through the phases. otherwise, head to a motor factors, gsf do them for a bout 30-35 quid each side
Threads: 4
skyline2k Wrote:hi i have a phase 3 2000 306 xsi that needs a new n/s lower arm im having trouble finding one .
as per the ones above that say it fits from 1998 to 2002 models.. yours is a 2000 model which fits in that range.
The main thing you need to confirm is if the balljoints are 16mm or 18mm. The phase 3's should have 18mm balljoints on the wishbones
Threads: 87
48
if you get one with the balljoint riveted on you need to make sure you have the right size balljoint, they come in 16 and 18 mm sizes . .
Threads: 9
19
samass Wrote:afaik they are all the same through the phases. otherwise, head to a motor factors, gsf do them for a bout 30-35 quid each side
Ball joints have 2 different sizes though (IIRC 16 and 18mm) make sure you get the right one though!
Edit:- OK this post is a waste of fecking time since 2 people have said the same thing since I started reply...........I've written it now, so just incase you didn't get it the first 2 times
Threads: 87
48
yeah i writ it and forgot to post and when i did Springs sprung up . .
Threads: 130
82
Yeh forgot about the ball.joints too...
Invade you didnt get it, there are two sizes, 16mm and 18mm. Yours is likely to be 18mm as its a ph3. :mrgreen:
Threads: 581
195
Almost guaranteed to be 18mm. Nice and easy to do, just 4 bolts but don't let the strut move out when the arm is off as it may pull the shaft out of the box - never good news!
Also, you will want a new pinch bolt with the ball joint
Threads: 171
46
well incase you missed it the first 4 times, youll need to watch out for the balljoints
they come in 18mm and 16mm
probably the 18mm though
Threads: 448
51
Watch out for the ball joints as there are 16mm and 18mm sure yours would be 18mm though......
Threads: 94
Theres something about ball joint sizes buddy you should start a thread and find out im not too clued up on it..
Threads: 130
82
Threads: 92
43
It could be 16mm... you know what peugeot are like
Threads: 9
19
Connor Wrote:It could be 16mm... you know what peugeot are like
But then it might be 18mm also
Threads: 171
46
Threads: 169
91
No seriously, you want to make sure its either the 16 or 18mm ball joint and then be sure not to let the strut flex out and cause the driveshaft to slip out of the gearbox...
Threads: 198
135
Threads: 130
82
just below your penis. holds your balls on. pretty important to be fair, dont want the wrong size
Threads: 9
19
:laughing-rolling:
I think that is pretty clear, and Niall makes a good point about the drive shaft and also that you need to be careful about the size of the ball joints on the lower arms.........
Threads: 131
6
Car Model/Spec: MX5
So either 16mm or 18mm right?
Threads: 91
12
Car Model/Spec: 306 D Turbo
Could someone please clarify the issue of what ball joints are needed. Still a bit unsure..........!!!
