Urgent brake help
Urgent brake help
So my brake pedal is solid and braking is very sketchy feels like I don't have any brake servo helping the braking. Anyone had a similar experience?
is there any vacuum ?
pipes split collapsed ant the bends or joints?
yes i have had this it was a collapsed vac pipe between vac pump and bulkhead
GTI6 Info
(27-11-2015, 12:36 PM)cully Wrote: is there any vacuum ?
I'll take a look now weird how it just randomly happen
Can't find any leak or damage to any pipes
is there vacuum anywhere?
disconnect the pipes to check
GTI6 Info
Try taking the pipe off the vac pump and see if its got any suck there
Have you/anyone else been in the engine bay recently? Probably disturbed something if it's gone like that suddenly.
Blank EGR pipe with a screw that's fallen out?
There's no vaccume between the pipe on the bulk head and the servo
Is there any at the vacuum pump then?
the black n white plastic 3 way joint lost its rubber tit? or broken off
GTI6 Info
None coming from here
spay some wd40/plusgas in their the valve may be stuck if not the pump is fubared
GTI6 Info
You'll need to get used to man braking till you get it repaired but if it is just a lac of vac the system will be fine bar being very heavy.
