16-10-2013, 01:31 PM
Only way to tell is to get it mapped on here and rolling road it in autotune again, if mines mapped ill be going to the rolling road day up there to see if it comes near that
306 FMIC FAQ
16-10-2013, 01:43 PM
He can't be that good if he's never seen over 150... Mine made nigh on 155 and that was with a boost leak and sticky caliper
16-10-2013, 01:56 PM
16-10-2013, 02:02 PM
yeah as they say if he hasnt seen one over 150 before he's on a different wavelength to prosteve altogether
16-10-2013, 10:06 PM
He is the most reputable person to map cars over here though
16-10-2013, 10:07 PM
Wouldnt say most reputable, depends what youre after. Theyre jusy widely known, id speak to mad tuning with regards to it see what he can do if you dont want to go pro steve
16-10-2013, 10:25 PM
Who's that?
16-10-2013, 10:28 PM
Mark Stirling, quote low key on the remapping scene but he does a good few dofferent motors. Mapped my zr along with a load of others I know with good results.
16-10-2013, 10:29 PM
I can only think of ProSteve, MrWhippy and TB205.
All of which are highly recommendable.
17-10-2013, 08:42 AM
Will see how the clutch goes and might get another map at some point
219lbft?? That's really low, he must have missed some of the torque limiters or something. Shouldn't bother with another clutch mate, you don't need it - i'm running ~235 on my stage 1.5 from pro_steve atm and it's fine.
24-02-2015, 08:40 PM
Hi guys just mid way through fitting another engine in my HDi and am fitting an Intercooler at the same time, I have all the pipe work and the 406 top elbow etc only thing Im struggling with is the lower pipe from the turbo, I got the 406 Hdi lower pipe but wasnt impressed with the way it fits, its hard against the sub frame just under the turbo and fouls the pas pipe next to the bell housing ?, From what Ive read the Citroen C5 lower pipe is the best to go for ? Does any one have the part no for this?
Thanks In advance Tris
19-11-2015, 11:49 AM
For an xud fitting a fmic do I need the 406 inlet manifold and turbo pipe?
19-11-2015, 12:26 PM
(16-10-2013, 01:43 PM)Midnightclub Wrote: He can't be that good if he's never seen over 150... Mine made nigh on 155 and that was with a boost leak and sticky caliper Well if you had a sticky caliper any dyno readings are fairly pointless then... A sticky caliper will on most dynos cause high numbers..not low.... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
19-11-2015, 12:35 PM
(19-11-2015, 12:26 PM)darrenjlobb Wrote:(16-10-2013, 01:43 PM)Midnightclub Wrote: He can't be that good if he's never seen over 150... Mine made nigh on 155 and that was with a boost leak and sticky caliper That post was over 2 years ago, but ok. Care to explain why, more load or something like that? and do you mean for the flywheel figure or any figure in general. Either way the original point still stands - that they can't be that good if they've never seen over 150, given whippy, steve etc.. make well over that for less money
19-11-2015, 01:27 PM
Most dynos are setup like poo and will massively exaggerate the losses on coast down because of the caliper sticking vs the actual power lost on acceleration... In theory it should make no difference, as this is part of the point of the coastdown, but unless the dyno's inertia settings are all set spot on (takes a fair bit of time to do) then it just ends up being wrong, which generally seems to be the case!
19-11-2015, 01:56 PM
(This post was last modified: 19-11-2015, 01:59 PM by Midnightclub.)
In my mind that would surely mean the only figure affected would be the flywheel figure as that uses the coast down to work out losses and add that onto the wheel figure or am i completely off base?
The dyno was supposedly calibrated recently before we went but who knows, the figures for Ruans DT seemed fairly spot on at the time as did connors poorly HDi. Good to know though
19-11-2015, 06:45 PM
(19-11-2015, 01:56 PM)Midnightclub Wrote: In my mind that would surely mean the only figure affected would be the flywheel figure as that uses the coast down to work out losses and add that onto the wheel figure or am i completely off base? Hm is this the dyno day with Ruans black DT? If so iirc it was a Dyno Dynamics unit anyway? So doesn't coast down in shootout anyway, just talks random numbers to keep everyone happy | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
20-11-2015, 09:36 AM
Yeah the black DT but nah wasn't a dyno dynamics, pretty sure it was a sun something, maybe microsystems dyno? It said what it was on the dyno graph but it was so long ago i can't remember tbh it might be in this/or another thread somewhere
