Threads: 58
those beam specs are way out :/ if you remove the arb bolts youll find it might have some play in it. I suspect either a worn pin or dying bearings.
Threads: 141
35
(07-11-2015, 11:39 AM)Stef205 Wrote: those beam specs are way out :/ if you remove the arb bolts youll find it might have some play in it. I suspect either a worn pin or dying bearings.
yeah man Ive been meaning to give you a message ; ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png) ts on the list of winter jobs to sort the beam out
Threads: 58
yeah no worries buddy
Threads: 141
35
Something to keep me busy
Threads: 465
114
Car Model/Spec: Vauxhall
oow a box of broken bits!
Threads: 141
35
(11-11-2015, 08:40 PM)cully Wrote: oow a box of broken bits!
Does look that way ![lmao lmao](https://www.306oc.co.uk/forum/images/smilies/legacy/lmao.gif) lot of cleaning to do and have a new backing plate cut
Threads: 465
114
sell them to me i want that BWARP Noise
Threads: 42
28
I still want wheels like yours!
Threads: 61
11
Nice.so you sold the bike bodies and got the proper ones
45's ??
Threads: 42
28
bike bodies are proper bodies, much higher quality.
Threads: 141
35
(12-11-2015, 06:47 PM)7057sam Wrote: Nice.so you sold the bike bodies and got the proper ones
45's ??
Yeah man, these came up for the right price including emerald k6 with a map for standard cams, wiring loom, jenvey 45's, longman inlet manifold, air filter, trumpets and 480 injectors :
Bolt on kit, got a lot of bits I want to do on the car before fitting though:
Beam rebuild
Epas setup
Battery relocation
New suspension
Possible satchshift
Change wiring loom
Fit emerald
Fit jenveys
Devise better air intake
Hopefully be running and ready by fcs next year, possibly even with some new cams and mapping work if funds permit
Threads: 42
28
it will need mapping regardless.
Threads: 81
Car Model/Spec: Black Rallye
Given 8 thank(s) in 8 post(s)
What's your time scale dude? Would love to see this on bodies for the shows next year!!
CLUB RALLYE
Threads: 141
35
(13-11-2015, 09:28 PM)Orta Wrote: What's your time scale dude? Would love to see this on bodies for the shows next year!!
Hope to have it all together for fcs next year
Threads: 3
Car Model/Spec: 306 estate and 106 swap jp4
Country:
good video and nice car
Threads: 141
35
Thought it was about time to make a start on getting the 6 ready for spring/summer.
Dragged it out of the corner, up on the ramp and got the beam off ready to fit the rebuilt one I'm collecting off stef tomorrow
Next up I need to do the cambelt, ill order a gates kit and a genuine waterpump through work next week, order some new bilsteins then see about some breathing modifications
Threads: 61
11
What bilsteins you going for ?
The more I drive mine the more I think a good set of shocks and springs would of been the better idea.
81
(06-02-2016, 05:26 PM)7057sam Wrote: What bilsteins you going for ?
Ive been thinking this too :/
Threads: 141
35
Ordering a set of Bilstein b8 from demon tweeks as they're on sale at the moment, £504 for front and rear
07-02-2016, 07:58 AM
(This post was last modified: 07-02-2016, 07:59 AM by Piggy.)
If in no rush...check out ebay germany for bilstein
If not...even ebay uk comes in a lot cheaper than 504
Threads: 110
20
(07-02-2016, 07:58 AM)Piggy Wrote: If in no rush...check out ebay germany for bilstein ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
These?
http://www.ebay.co.uk/itm/Bilstein-B8-Am...5681a91f3f
Threads: 141
35
Just the postage to worry about with buying from Germany?
I might give Bilstein uk a call as we buy alot of stuff from them direct at work
Threads: 102
18
07-02-2016, 01:09 PM
(This post was last modified: 07-02-2016, 01:10 PM by RetroPug.)
They're about that from Kam Racing as well:
http://www.kamracing.co.uk/car-tuning/pe...r-kit.html
Or, if this is for all four corners ít is a great price and worth calling and asking about??
http://www.kamracing.co.uk/car-tuning/pe...n-kit.html
Koni Yellows which are what I run were a good price on there but don't seem to be available from there anymore.
I'd love an ITB setup like that!
Threads: 61
11
Nice what springs are you using them with? eibachs?
(07-02-2016, 11:22 AM)ozonehostile Wrote: Just the postage to worry about with buying from Germany?
I find its often free postage from Germany for most bits I buy
Threads: 141
35
09-02-2016, 10:41 AM
(This post was last modified: 09-02-2016, 10:41 AM by ozonehostile.)
(09-02-2016, 01:38 AM)7057sam Wrote: Nice what springs are you using them with? eibachs?
Not sure yet, annoying thing about eibach is that they don't really do any springs lower than 30mm where I'm looking to go about 45-50mm
(09-02-2016, 07:05 AM)Piggy Wrote: (07-02-2016, 11:22 AM)ozonehostile Wrote: Just the postage to worry about with buying from Germany?
I find its often free postage from Germany for most bits I buy Good to know :p
81
Ive found the same thing looking into suspension setups. I wouldnt mind getting rid of the avos but the bilsten and eibach combo only really seems good for 30mm :/
Threads: 42
28
thats because any more than 30mm is daft without proper suspension work to make it work properly.
Threads: 45
Car Model/Spec: HDi DTurbo 2001(Y) Astor
^ I'm sure he's got that covered. Especially given his new line of work [emoji28]
Team disASTOR?
