water pipe problem
water pipe problem
had to change the clutch cable today and noticed the water pipe flange on the rear of the engine had a pipe missing.
it has the pipe connected that runs along the drivers side arch but beside it there a open end with no pipe on. is it missing a pipe or is it a blank?
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
Its for the water cooled egr which I'm guessing you don't have? would be 2001 models that tend to have it
(08-11-2015, 03:28 PM)HDi--Power Wrote: Its for the water cooled egr which I'm guessing you don't have? would be 2001 models that tend to have it
thats good then. is it supposed to have a blank on it? or is it blanked inside it? thanks
Its just blanked inside, usually requires "trimming" to fit a bigger turbo
I saw mine had an extra pipe that is internally blanked, didn't know it was for the watercooled EGR but that makes sense.
Hard to find the blanked one from a motor factors, so have bought one and a silicone bung to go with it.
  Water pipe BoldieRob 4 2,814 09-03-2017, 08:19 PM
Last Post: toseland
