Threads: 448
51
03-10-2015, 01:16 PM
Went to change the fan switch and it turns out I've ordered the wrong one, the new one has 2 contacts where the old one has 3?
What is the centre connection for? And can I fit this one?
I need the rallye ready for mot on Monday, but they can't do emissions and as fans don't kick in until about 110c+. Is that normal? Anything I can do?
Threads: 42
28
2 pin is 1 speed, 3 pin is 2 speed.
go to motorfactor on way to mot.
Threads: 448
51
Ahh shit, it's not that easy on the Isle of Wight haha, closest one is 7miles! What temperature should the fans kick in?
Threads: 11
5
Given 2 thank(s) in 2 post(s)
Threads: 15
2
Car Model/Spec: XSi
Just bridge over it for the mot test. Factor ones don't last long from experience
P1 XSi track car
2.4 LWB T4
Threads: 448
51
How would I bridge it? I know how to do something with aircon but this doesn't have it
Threads: 11
5
03-10-2015, 04:34 PM
(This post was last modified: 03-10-2015, 04:39 PM by vincent1.)
Threads: 448
51
Just to note my doesn't have a brown sensor as is a rallye. I have a sensor in the rad which controls the fans. Is the plug bridgeable so I could put it a switch attached to two wires and the to the switch. Use the switch to close bridge when I want them on?
Threads: 11
5
03-10-2015, 08:59 PM
(This post was last modified: 03-10-2015, 08:59 PM by vincent1.)
ive done that on various cars in the past as a tempory measure so should be fine although im not sure which ones to bridge on a thre terminal one.
Threads: 15
2
Car Model/Spec: XSi
Think it's the outer two. Well it works on my bastard of a car!
P1 XSi track car
2.4 LWB T4
Threads: 374
38
Car Model/Spec: GTI 6
(03-10-2015, 11:25 PM)adam b Wrote: Think it's the outer two. Well it works on my bastard of a car!
We tested this ; and the fans kicked in, but would that help for 2 speed?
Matt's fans do kick in, but at higher temp, no lower temp kick in
Threads: 15
2
Car Model/Spec: XSi
The fuses and relays on the fan cowling ok? Bridging it kicks in low speed
P1 XSi track car
2.4 LWB T4
Threads: 374
38
(04-10-2015, 07:52 AM)adam b Wrote: The fuses and relays on the fan cowling ok? Bridging it kicks in low speed
We bridged and it kicked in.
But the fans don't actually kick in on their own until nearer 110
Threads: 42
28
04-10-2015, 08:07 AM
(This post was last modified: 04-10-2015, 08:08 AM by welshpug.)
low fan should be sufficient, obvious symptoms of failing thermoswitch if it'll run with the pins bridged, if ut didnt then youll have a failed resistor.
Threads: 448
51
Thermoswitch being the one on the rad? That's the one I ordered the wrong one of haha but yeah fans come on just a little to late
Threads: 374
38
(04-10-2015, 08:15 AM)Matt Wrote: Thermoswitch being the one on the rad? That's the one I ordered the wrong one of haha but yeah fans come on just a little to late
I'd keep it as it is, especially as it's getting colder anyway... get it on the road!
Threads: 448
51
Yeah but I can't mot it as they think it's overheating and won't do emissions on it haha
Plus with my hand in cast, putting wheels and a exhaust is gunna prove difficult haha
Threads: 42
28
youll just have to wait then!
Threads: 448
51
Sorted wheels and exhaust, fan switch I can't test as I now have a problem with the idle :/
Threads: 374
38
(04-10-2015, 06:23 PM)Matt Wrote: Sorted wheels and exhaust, fan switch I can't test as I now have a problem with the idle :/
did you unplug the ICV - see if it made any difference?
Threads: 448
51
Got side tracked yesterday. And it was pissing it down today so doing it tomorrow morning
Threads: 4
Car Model/Spec: 306 Gti6
Country:
Mine is a normal 6 and i have the same issue - will run when bridged but i only have the high speed fan that works like you. Really interested to see if you solve this as mine has been like it for 18 months
Threads: 448
51
Just needs a new switch.
Is yours the switch that is in the rad?
Going to bridge it to get it through the mot.
Anyone know which pins to bridge?
