Fueling bits
Fueling bits
10mm fuel filter housing that has primer built in with spare brand new filter. £15
9mm bosch gov mod. Needs reseal. £30
11mm bosch pump hasnt been ran yet but took apart to fix. Didnt re seal. Should be fine. £50
Loads of bosch ve spares.
All prices are plus postage. Need rid. Need the money.
I'll have the 11mm pump when I get paid on Wednesday if that's cool?
Fine by me. Provisionaly sold.
9mm pump sold as well.
Has 11mm gone ?
Provisionaly sold to Paul pending payment.
Ahhhhh bash what a savior I need the black lever bit and at least one of the little springs how much posted with asap posting Wink
There are lots of little springs. Lol. Lever set i have springs i probably have as well. The return springs?
    these ones
also if you have the lower right hand mounting bolt and nut (the one by the injectors) that would be pretty cool. Is the Bosch pump meant to be on the more advanced stud pattern on the bracket ? Cheers
Got the internals not sure about the bolt though. Ill look today. Say £10 posted?
That's great cheers Pm me you details and I'll put the money in
These bits. And pmd
do you have a ve advance piston, and a 'idle' spring (the spring inside the pump that fits between the leverset and cold/hot idle lever)
cheers
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
Send me your payment details mate please
by any chance do you sill have the filter housing if so do you have a pic/ruff size Smile
