DervMafia Eddy Current Dyno Upgrade
#61
Good effort pal!!
Defo need a 306oc day!!
Looks fcuking belting mate, nice work Smile
Awesome work.
So how do you go about getting new bearings and bits for it, do you order from the manufacturer or are they built using sorta standard sized parts you can order for an engineering supplies place??
Awesome updates and i'm loving the colour! Can't wait to come and see it Smile
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
(15-09-2015, 03:35 PM)silverzx Wrote: Thanks Darren, just for me? Big Grin
Haha not just for you, need to get a baseline on the 505 before we strap turbo on to blow up the stock motor!! But did also have you in mind Smile
(15-09-2015, 03:43 PM)Stef205 Wrote: Nice work Darren! So when is the 306oc dyno day? lol
Heh, I have thought about organising a meet up down here before, trouble is Cornwall is miles out the way for 90% of people, so not ideal, but maybe do a SQ 306oc meet up / dyno fun day or something....free tuning opportunity etc!
(15-09-2015, 04:23 PM)r3k1355 Wrote: Awesome work.
Depends on what it is really, but bearings and seals on this have been much easier to get hold of, all fairly standard metric sizes, so have found everything online in decent skf brands etc, which has made life alot easier!
(15-09-2015, 06:46 PM)Anton Wrote: Awesome updates and i'm loving the colour! Can't wait to come and see it Smile
Heh, will have to drop Volvo / S16 on to test it out!!
[Image: sigi-2.png]
looks like standard rr blue Big Grin
which bit of Cornwall are you in?
Dyno day at darren good luck getting your lowered car down his lane Smile
(15-09-2015, 08:07 PM)welshpug Wrote: looks like standard rr blue Big Grin
St.Austell area.....
(15-09-2015, 08:53 PM)daniel909 Wrote: Dyno day at darren good luck getting your lowered car down his lane Smile
Haha pft, no issues if you know how to drive Wink
[Image: sigi-2.png]
Or just be like me no shit given!!
Also popped over the other night no one was around the v5 in my glove box will drop in on the way back from work if I remember
Ill bring the Kia down to see how much raw power it has left after being in my care for 3 years lol
haha ill be on there alday if you say things like that! Dont worry about the people that cant make it thats their fault for living in the wrong area Tongue
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Top work Darren. Looking very smart work as per usual
looks good ted much left to do till she is done ?
you're not far at all from Sandy Brown then Smile
Not a huge ammount left to do, concrete in some new strap points, sort ramps, and sort wiring / software etc, altho have had a car on now for some preliminery testing, will update thread shortly.
And yes, Where is Sandy Brown? Lanson?
[Image: sigi-2.png]
Par I believe.
where's Lanson? he usually maps in Lauceston or Saltash.
SRD Launceston or saltash is nr plymouth, both about an hour from darren Wink
Darren is not far from the Eden project
Lanson is local dialect for Launceston
GTI6 Info
(16-09-2015, 09:33 AM)welshpug Wrote: Par I believe.
Sorry = Launceston!
(16-09-2015, 09:58 AM)cully Wrote: SRD Launceston or saltash is nr plymouth, both about an hour from darren Wink
This! Less than an hour from Launceston though
[Image: sigi-2.png]
Debatable if you catch it at the wrong time time through those temple roadworks
Heh yeah well atm there can be some delays at busy times...should be good once its finished though!
[Image: sigi-2.png]
indeed, last time I was down there for mapping Sandy was delayed a fair bit with the road works!
Great news, can't wait to see it in action. Big Grin
Looks awesome in the blue mate, far more pro than the yellow (which was very cool)
Long overdue update here, been all sorts going on, but dyno has been shaping up to!
Next step was to get the rest of the eddy brake back together, which meant new bearings / seals for the center drive hub, and re wiring the coils etc.
So with the core removed the retarder looked much like this:
[Image: DSC_0325.jpg]
And then stripped it down...as you can see this has been dry / no oil in here for some time!
[Image: DSC_0324.jpg]
So ordered up some new bearings and lip seals, all sizes were metric, so nice and easy to source, which made a nice change!
[Image: DSC_0364.jpg]
Got them mounted up on shaft..
[Image: DSC_0368.jpg]
And back in the center:
[Image: DSC_0370.jpg]
Cleaning up the very crudded / blocked vent tube!
[Image: DSC_0374.jpg]
And got it back in the retarder, leaving me with a fully assembled driveline ready for rotors etc and rewiring!
[Image: sigi-2.png]
I decided to make some new floor anchors this time rather than attaching to the dyno frame, so have sunk two in the front and two behind the front wheels, to allow 4 straps rather than 2 at front, meaning a strap can fail and no disaster! Over the top, yes maybe, but better safe than sorry!
Weld up some hook anchor points...
[Image: DSC_0442.jpg]
Made some holes....
[Image: DSC_0448.jpg]
[Image: DSC_0449.jpg]
And job jobbed:
[Image: DSC_0450.jpg]
Also got the new load cell fitted and calibrated:
[Image: DSC_0445.jpg]
[Image: DSC_0453.jpg]
And made up a mount / fitted the roller speed sensor, normal Hall type sensor:
[Image: DSC_0458.jpg]
Also made up some ramps, although have hopefully got hold of some better, much wider / sturdier ones for the long run, but this will do until I get them back here, Thanks to James / Ruan etc who were down helping out this day!
[Image: DSC_0388.jpg]
[Image: sigi-2.png]
Calibrating with a tractor nose weight?
(27-09-2015, 09:35 PM)Piggy Wrote: Calibrating with a tractor nose weight?
Got to have some sort of agri spec in there. lol
Indeed, 50.04kg exactly!
[Image: sigi-2.png]
The .04 been dirt and oxidisation Smile
Next little job now things were getting together and looking nearly finished was to make a cover for the retarder end of the dyno, sadly we never got the original, not sure what happened to it but the guy I picked it up from never had it either, so decided to just make one up from scratch.
So started by boring a hole out the pit for all the cables to tidy things up:
[Image: DSC_0464.jpg]
And then cut up some lengths of angle to form the outer frame / lip that will sit down in the dyno frame, idea being this cover will simply lift off for servicing etc.
[Image: DSC_0471.jpg]
Welded that up to form frame:
[Image: DSC_0474.jpg]
Promptly realised I had made epic fail with measurements (measure ID not OD of the hole!!) so had to weld in extensions on all four sides, so did that and then ground all the welds flat so sheet steel would fit flush:
[Image: DSC_0476.jpg]
Sits like so:
[Image: DSC_0478.jpg]
Welded some inch box in to strengthen it so you can walk on it without bending the sheet steel (not that we walk on it on purpose but just incase!...Regular people who visit my workshop will know the rules around the dyno hehe Big Grin  )
[Image: DSC_0480.jpg]
[Image: DSC_0481.jpg]
Cut up some sheet steel and tacked corners to form the basic shape / check fit and clearance etc:
[Image: DSC_0484.jpg]
Torched some holes in the top with the plasma cutter for some fans to pull heat up out the hole:
[Image: DSC_0490.jpg]
And welded her around, not the best welding but got bord going slow and keeping it pretty so just blasted around to get the job done!:
[Image: DSC_0491.jpg]
[Image: DSC_0494.jpg]
And a lick of paint / fans fitted ended up looking like this, which has done the job nicely!:
[Image: DSC_0496.jpg]
Thanks for reading Smile
[Image: sigi-2.png]
  Your current 'fleet'? Matt-Rallye 72 12,651 04-05-2016, 06:08 AM
Last Post: Jonny81191
  Current Scrap Prices? Toms306 33 7,092 19-11-2015, 10:33 PM
Last Post: Toms306
  enigne swap or tune current 7057sam 15 5,136 14-11-2012, 11:29 AM
Last Post: Tom
Users browsing this thread: 27 Guest(s)
