TPS
Hi all,
I've been given a TPS ( shown on the picture) witch apparently should fit my 306 HDI.Can anyone tell by the number if this is any good for my car?Thanks.
Dim
If its the same shape(looks like it is) it will fit, they were all the same from 406's, 206's grand vitara etc, anything that had one
^this, also just plug it in and see, it'll work without being bolted on so it's only a 2 min job to test it
it will throw a code if its wrong but wont cause any issues permanently. if the glove fits..
/Toseland
I've just bolted it on and took a quick drive...no EML on, the car have more power in the higher revs.Is it possible in case it's a wrong one to store a silent code?I've thought they have different rates potentiometers depending of the model.Regards
Maybe your old one is defective hence noticing the power
it wouldnt make anyt difference..
i just know that if its not the right one the car says "f**k you" and starts flashing at you.. also does if you unplug it with ignition on etc, i had to reset mine
/Toseland
