TPS - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: TPS (/showthread.php?tid=31775)
TPS - dimar - 01-09-2015
Hi all,
I've been given a TPS ( shown on the picture) witch apparently should fit my 306 HDI.Can anyone tell by the number if this is any good for my car?Thanks.
Dim
RE: TPS - HDi--Power - 01-09-2015
If its the same shape(looks like it is) it will fit, they were all the same from 406's, 206's grand vitara etc, anything that had one
RE: TPS - Jonny81191 - 01-09-2015
^this, also just plug it in and see, it'll work without being bolted on so it's only a 2 min job to test it
RE: TPS - toseland - 02-09-2015
it will throw a code if its wrong but wont cause any issues permanently. if the glove fits..
RE: TPS - dimar - 02-09-2015
I've just bolted it on and took a quick drive...no EML on, the car have more power in the higher revs.Is it possible in case it's a wrong one to store a silent code?I've thought they have different rates potentiometers depending of the model.Regards
RE: TPS - MrBigMac - 02-09-2015
Maybe your old one is defective hence noticing the power
RE: TPS - toseland - 03-09-2015
it wouldnt make anyt difference..
i just know that if its not the right one the car says "f**k you" and starts flashing at you.. also does if you unplug it with ignition on etc, i had to reset mine
