Threads: 21
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
If its the same shape(looks like it is) it will fit, they were all the same from 406's, 206's grand vitara etc, anything that had one
Threads: 202
58
^this, also just plug it in and see, it'll work without being bolted on so it's only a 2 min job to test it
Threads: 128
21
Given 41 thank(s) in 38 post(s)
it will throw a code if its wrong but wont cause any issues permanently. if the glove fits..
/Toseland
Threads: 3
Car Model/Spec: 306 HDI Estate
02-09-2015, 10:33 AM
(This post was last modified: 02-09-2015, 10:38 AM by dimar.)
I've just bolted it on and took a quick drive...no EML on, the car have more power in the higher revs.Is it possible in case it's a wrong one to store a silent code?I've thought they have different rates potentiometers depending of the model.Regards
Threads: 7
Country:
Maybe your old one is defective hence noticing the power
Threads: 128
21
it wouldnt make anyt difference..
i just know that if its not the right one the car says "f**k you" and starts flashing at you.. also does if you unplug it with ignition on etc, i had to reset mine
/Toseland
