406 MC 23.8mm
406 MC 23.8mm
Does this have to come from a certain phase/age 406 or can it come from any age of 406 with abs?
The 406 2.0 L 16V is 23 mm. But the M/C size may be difference between Engine type
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
[Image: 150521115952.jpg]
theyre all the same
Cheers, is their any straight swap 23.8mm master cylinders other than gti6 one?
The gti is 23mm too, same as the hdi one.
Did read some where a vw transporter mc fits nicely, was thinking about doing it on my track car because the bit was a little low, but you loose a little progression then... should have all the info on my pc some where
Cheers lads!
