406 MC 23.8mm - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: 406 MC 23.8mm (/showthread.php?tid=31250) |
406 MC 23.8mm - MY95 - 18-07-2015 Does this have to come from a certain phase/age 406 or can it come from any age of 406 with abs? RE: 406 MC 23.8mm - maxzy - 18-07-2015 The 406 2.0 L 16V is 23 mm. But the M/C size may be difference between Engine type RE: 406 MC 23.8mm - welshpug - 18-07-2015 theyre all the same RE: 406 MC 23.8mm - MY95 - 18-07-2015 Cheers, is their any straight swap 23.8mm master cylinders other than gti6 one? RE: 406 MC 23.8mm - HDi--Power - 18-07-2015 The gti is 23mm too, same as the hdi one. RE: 406 MC 23.8mm - Lwilliams - 18-07-2015 Did read some where a vw transporter mc fits nicely, was thinking about doing it on my track car because the bit was a little low, but you loose a little progression then... should have all the info on my pc some where RE: 406 MC 23.8mm - MY95 - 18-07-2015 Cheers lads! |
