25-05-2015, 02:58 PM
1. Battery disconnected.
2.Stereo out.
![[Image: IMG_20141023_115254_zpsmkg1hsol.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141023_115254_zpsmkg1hsol.jpg)
3.There is a securing spring pin on the right of the air bag. Left inside the stereo hole. There may be a bolt to remove first to allow the sprung lever to be moved.
![[Image: IMG_20141023_115313_zpsihbva5px.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141023_115313_zpsihbva5px.jpg)
4. That should allow the air bag to be removed. Undo the wiring. Put a resistor in if you are keeping the airbag system. (1.8 ohm resistor .025 watt with a 2 amp fuse for overall 2.1 ohm resistance)
![[Image: IMG_20141023_115319_zpsebgbmno3.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141023_115319_zpsebgbmno3.jpg)
5. Remove the securing sprung pin by removing the two bolts on the right.
![[Image: IMG_20141023_120123_zpsspclrh8z.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141023_120123_zpsspclrh8z.jpg)
![[Image: IMG_20141023_120243_zpsidthpc56.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141023_120243_zpsidthpc56.jpg)
6. The air bag sits in a metal surround which is riveted to the dash. Get a drill and you can easily get through these. Leave the glove box closed and they will all fall into there which keeps tings tidy. Remove the torx screws too.
![[Image: IMG_20141024_151210_zpsly9e60z3.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141024_151210_zpsly9e60z3.jpg)
![[Image: IMG_20141024_152233_zpsqqhxx4vb.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141024_152233_zpsqqhxx4vb.jpg)
![[Image: IMG_20141024_152322_zpseczzvchu.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141024_152322_zpseczzvchu.jpg)
6. Once the metal frame is removed you can screw in the top glove box. However the rivet holes are larger than what the screw holes should be so its a bit wobbly!
![[Image: IMG_20141024_152527_zpsjwwrp1l5.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141024_152527_zpsjwwrp1l5.jpg)
![[Image: IMG_20141024_152534_zps8leaiwif.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/IMG_20141024_152534_zps8leaiwif.jpg)
7. Radio back in and battery reconnected. Done!
2.Stereo out.
