Guide: Fitting a Top Glove Box - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Guides (https://www.306oc.co.uk/forum/forumdisplay.php?fid=9) +--- Thread: Guide: Fitting a Top Glove Box (/showthread.php?tid=30591) |
Fitting a Top Glove Box - Eeyore - 25-05-2015 1. Battery disconnected. 2.Stereo out. ![]() 3.There is a securing spring pin on the right of the air bag. Left inside the stereo hole. There may be a bolt to remove first to allow the sprung lever to be moved. ![]() 4. That should allow the air bag to be removed. Undo the wiring. Put a resistor in if you are keeping the airbag system. (1.8 ohm resistor .025 watt with a 2 amp fuse for overall 2.1 ohm resistance) ![]() 5. Remove the securing sprung pin by removing the two bolts on the right. ![]() ![]() 6. The air bag sits in a metal surround which is riveted to the dash. Get a drill and you can easily get through these. Leave the glove box closed and they will all fall into there which keeps tings tidy. Remove the torx screws too. ![]() ![]() ![]() 6. Once the metal frame is removed you can screw in the top glove box. However the rivet holes are larger than what the screw holes should be so its a bit wobbly! ![]() ![]() 7. Radio back in and battery reconnected. Done! RE: Fitting a Top Glove Box - kentiiboii - 25-05-2015 Nice one sam. :-) Once I've done this I'll have no airbags, do you know if I just fit resistors to everything, or can I remove the whole system. Obviously I need light for mot reasons. RE: Fitting a Top Glove Box - 1616six - 25-05-2015 Surely using U nuts would be a safer option over it just 'being a bit wobbly'? http://pages.ebay.com/link/?nav=item.view&alt=web&id=320997909814 RE: Fitting a Top Glove Box - Eeyore - 25-05-2015 Yep good one JJ. Would probably work! Just haven't done anything about it as wobbly was good enough. If you've removed all the airbags and pretensioners (i.e. running buckets) then you should be able to remove the airbag ECU and no resistors. Wiring will still obviously be there unless you fancy stripping the car and stripping looms. RE: Fitting a Top Glove Box - cully - 25-05-2015 (25-05-2015, 08:54 PM)Eeyore Wrote: If you've removed all the airbags and pretensioners (i.e. running buckets) then you should be able to remove the airbag ECU and no resistors. Wiring will still obviously be there unless you fancy stripping the car and stripping looms. the airbag light will stay on as there is a lamp link in the airbag loom that triggers when its all unplugged you can remove the lamp or remove the link the link is easier to get to than the lamp in the dash
RE: Fitting a Top Glove Box - Mattcheese31 - 25-05-2015 Turn the airbag off with the key near the headlight adjuster
RE: Fitting a Top Glove Box - kentiiboii - 26-05-2015 (25-05-2015, 10:32 PM)Mattcheese31 Wrote: Turn the airbag off with the key near the headlight adjusterThis just keeps the light on, to let you know it's turned off. :-) Btw I did this yesterday, cheers sam :-) Just need something in its place. RE: Fitting a Top Glove Box - Mattcheese31 - 26-05-2015 Ahh sorry didn't realise, when I did it on the wife's car airbag light was on anyway lol RE: Fitting a Top Glove Box - aa234 - 28-05-2015 Nice tutorial, thanks! ford servicing |
