Threads: 102
18
Anyone got one of these lying around?
81
what actually is needed to fit the cat? its only the fire ring and bolts for the manifold?
Threads: 1
Car Model/Spec: Supercharged Gti 6
Euro car parts do a full fitting kit for £12 give or take
Threads: 102
18
Thanks guys. Had a really bad experience with ECP recently but what can you do?
Yeah just a fire ring, and bolts and all the misc springs and cups and top hat washers etc.
Threads: 1
You can also get all the bits on ebay but its pricey on there and most of the time its euro car parts trading under a different name.
Threads: 110
20
Give peugeot a try, got a kit for jimbo's hdi back along and that wasn't overly expensive and at least you know it will be the right parts
Threads: 102
18
That does look like the right one, thanks. In the end I found one online somewhere that was 12something posted and appeared correct so I bought that.
Threads: 102
18
How much should the cat be able to move with the bolts tightened up?
Threads: 465
114
Car Model/Spec: Vauxhall
it will move up down left right on the fiber ring but it should be tight
Threads: 102
18
Ok good thanks for your help. Hopefully the new kit won't be made of cheese!
