Gti6 Cat Fitting Kit - Printable Version
+--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14)
+--- Thread: Gti6 Cat Fitting Kit (/showthread.php?tid=30502)
Gti6 Cat Fitting Kit - RetroPug - 17-05-2015
Anyone got one of these lying around?
RE: Gti6 Cat Fitting Kit - Eeyore - 17-05-2015
what actually is needed to fit the cat? its only the fire ring and bolts for the manifold?
RE: Gti6 Cat Fitting Kit - 6waysforward - 17-05-2015
Euro car parts do a full fitting kit for £12 give or take
RE: Gti6 Cat Fitting Kit - RetroPug - 17-05-2015
Thanks guys. Had a really bad experience with ECP recently but what can you do?
Yeah just a fire ring, and bolts and all the misc springs and cups and top hat washers etc.
You can also get all the bits on ebay but its pricey on there and most of the time its euro car parts trading under a different name.
RE: Gti6 Cat Fitting Kit - RetroPug - 18-05-2015
Thanks. My ebay feed used to be full of genuine kits but they've all gone now that I need one. lmao
RE: Gti6 Cat Fitting Kit - Frosty - 18-05-2015
Give peugeot a try, got a kit for jimbo's hdi back along and that wasn't overly expensive and at least you know it will be the right parts
RE: Gti6 Cat Fitting Kit - cully - 18-05-2015
is this the right one?
http://www.ebay.co.uk/itm/330777041813
That does look like the right one, thanks. In the end I found one online somewhere that was 12something posted and appeared correct so I bought that.
RE: Gti6 Cat Fitting Kit - RetroPug - 27-05-2015
How much should the cat be able to move with the bolts tightened up?
RE: Gti6 Cat Fitting Kit - cully - 27-05-2015
it will move up down left right on the fiber ring but it should be tight
RE: Gti6 Cat Fitting Kit - RetroPug - 28-05-2015
Ok good thanks for your help. Hopefully the new kit won't be made of cheese!
