Threads: 122
9
Given 7 thank(s) in 7 post(s)
Been given the task by a customer at work to find some parts for a 205gti
Car is a 89 F plate in white
After
Gear knob 5spd reverse behind 5th
Rear boot trim no badges required
Fog lights front
1 1.9 gti speedline alloy wheel in original colour
Thanks, i know a few on here might have connections with 205 lads or be able to point me in the right direction
Threads: 42
28
gti's rarely had fog lamps, they would be Driving/spot lamps.
the Denji lamps might at a glance look the same, but they don't bloody fit properly, and rust away even faster than the original ones.
if you do still have some grotty originals with intact glass, keep hold of them as Stew at BBM is working on a replacement reflector and possibly the surround, though someone on the 205 forum has replicated those already.
Threads: 122
9
Cheers guys, I was told the great knob would be the hardest to source
Threads: 58
ive a rear boot trim here somewhere that you can have.
