gti6 high rpm flat spot
(20-03-2015, 10:45 AM)Midnightclub Wrote: A stock GTi6 will not hit the limiter in 6th, 100%. You'd need a massive down hill section at least!
I kind of thought that! The Gti 6 is geared totally different to any car that I've driven, I can do 30mph in 6th! Smile lol!
It gets bloody close though Wink
And bloody scary!!
Out of curiosity what does the speed in 6th gear top out at with the standard limiter? Anyone know? A friend of mine had a 410bhp 6 until recently and I'm sure that's been over 160mph.
I hit the end of the speedo on the autobahn on a downhill. Couldn't get a totally flat section but generally around the mid 120s to 130 I think but then that's indicated speed rather than actual speed. Don't think you quite hit the limiter, just reach a point where you can't overcome all of the drag forces eg. air resistance, friction, hysteresis in the tyres etc.
62k Diablo Phase 1 Gti-6:
Project Thread
(04-03-2015, 10:34 PM)Niall Wrote: Yeah the power hits its peak at 4.5k and really does tail after 6.5-7 so i wouldn't worry tbh. Theres no need to rag these 6's to the red line!
Shut up Niall,
Yes there is.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
If you own a petrol and don't take it to the limiter what's the point
[Image: mcetg0.png]
(21-03-2015, 08:47 AM)RetroPug Wrote: I hit the end of the speedo on the autobahn on a downhill. Couldn't get a totally flat section but generally around the mid 120s to 130 I think but then that's indicated speed rather than actual speed. Don't think you quite hit the limiter, just reach a point where you can't overcome all of the drag forces eg. air resistance, friction, hysteresis in the tyres etc.
I saw an indicated 140 in my completely standard rallye on the autobahn. Was then flashed out the way by a diesel touareg.
Hit the limiter when it was a v6 at 142 on satnav, now hits top gear limiter at indicated 134, should be about 126.
P1 XSi track car
2.4 LWB T4
  Flat spot/ miss fire on gti6 kentiiboii 11 6,812 21-02-2014, 12:26 PM
Last Post: kentiiboii
