Flat spot/ miss fire on gti6
So we picked the gti6 up today, it's nile blue not China but it's fairly tidy and drove well.
Problem is though sometimes when you boot it, it doesn't want to go like it has a miss fire or flat spot. We're thinking because it has a air filter on it might of killed the maf or something. Anyone got any ideas?
Thanks Kent.
Try unplugging the TPS
no MAF on a Gti6 Wink
check the fuel regulator vacume line or as said the TPS
give the air filter a clean Wink
Clogged fuel filter is also a quick/cheap thing to check
cheers, its only does it under heavy load. but not everytime just now and again.
ill give these a tryand see what happens. it needs a service and cam belt anyway.
Do GTi-6 have cam position sensors?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Mine does the exact same thing, and only when booting it from idle or rolling in gear/at very low revs. Worse when cold.
Think it's the TPS, have cleaned and tested the ICV and recently replaced it anyway, have switched MAP sensors and cleaned it. Will be trying TPS soon so will let you know if this fixes mine...
62k Diablo Phase 1 Gti-6:
Project Thread
(20-02-2014, 06:29 PM)RetroPug Wrote: Mine does the exact same thing, and only when booting it from idle or rolling in gear/at very low revs. Worse when cold.
Cheers for the info mate, I've given him tps from my gti to try see if it sorts it.
No worries.
You can test the TPS if you've got a multimeter.
Project Thread
(20-02-2014, 09:44 PM)RetroPug Wrote: No worries.
Will try it then :-) Cheers
[Image: TPS.jpg]
Here you go!
Project Thread
(21-02-2014, 11:07 AM)RetroPug Wrote: [Image: TPS.jpg]
Here you go!
Cheers for that. :-) much appreciated.
  gti6 high rpm flat spot aaddzz123 36 25,172 23-03-2015, 11:03 PM
Last Post: adam b
  Wont fire... no fuel! Matt-Rallye 11 7,151 25-02-2014, 03:49 PM
Last Post: kentiiboii
