What wheel bolts?
Am putting 307 wheels on 306hdi do I need longer bolts or do standard ones fit?
Blush
I'm assuming you mean challengers. Need spacers and wheel bolts to match
Or do as I've done and convert to stud and nuts. Wink still need the appropriate spacers to suit though, so make sure you get long enough studs.
It's a shame you only have 1 post, as there is a set of spacers and bolts just gone up in the for sale section. Itwasntme
So would 15mm spacers on the back and 10 mm on the front be fine to use?
iv got a set in the for sale thread
(21-02-2015, 09:21 PM)jayspug86 Wrote: iv got a set in the for sale thread
They can't access the for sale section as they have less than 100 posts. Wink
Depends what wheels they are you still have not told us. Of its challengers I think they need 10mm min at the back dependent on tyre size. Which means 10mm hubcentric spacer and 45mm flat seated bolts. As the standard ones are 35mm. Don't quote me on this though easiest thing to do is look at wheel offset. ET on the wheel. Then get that as close to standard with spacers
Sorry they are 307 challengers
Do you have to have 100 posts just to access the for sale section?? Why??
[Image: sigcopy-1.jpg]
http://306oc.co.uk/forum/showthread.php?tid=13874
Afaik, the 30 day limit has not been implemented, but the 100 post limit has. Smile
Seems fair to stop them posting new threads in that section, but not letting them buy stuff seems a bit daft, it's just a deterrent to people joining?
  Alloy Wheel Bolts rdstars 2 2,745 16-03-2017, 05:01 PM
Last Post: rdstars
  Wheel bolts PugRory 11 6,684 09-11-2015, 11:55 AM
Last Post: PugRory
  c5 steel/alloy wheel bolts Poodle 8 5,970 20-04-2015, 08:42 PM
Last Post: Poodle
