Threads: 58
22-01-2015, 10:28 PM
(This post was last modified: 03-02-2016, 10:06 PM by Stef205.)
Hi all,
Id thought id offer the members on here my budgeted beam builds. These will work on the basis of a supplied beam, they will be stripped, inspected, then rebuilt with new parts. This will include new bearings, seals, trailing arm shafts, arb bushes and seals. The tubes will be well greased with lithium grease as this does not eat into seals like general grease. They will have a quick de rust of any flaking material then painted in black paint. I can lower it to a required height other wise i will build it to the height it was received at.
I will be doing this at £220 Im purely offering this as i know some people do not want to spend big and this purely gives a choice. This will be available on drum and disc 306/205/309 axles, other model axles please pm me.
Thanks Stef
Threads: 61
11
How much do the courier's charge ??
Threads: 58
£30 via parcel monkey using DX couriers. I used them with the last axle I sent to Scotland.
Threads: 87
48
Is that an all in price? Just postage to yours on top or postage there and back?
Threads: 58
It would be postage on top for both ways.
Threads: 139
9
Car Model/Spec: Bianca Rallye 205 GTi6 197 Cup
If I supplied you a beam to refurbished and the tube was knackered, is there a cost for replacing the tube?
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
Threads: 58
Naturally I would not accept a seized beam, I would inspect the axle before its stripped. Generally I charge £40 for a good s/h tube. Also it is very hard to tell the inside condition of a tube until it is stripped.
Threads: 87
48
(23-01-2015, 11:19 AM)Stef205 Wrote: It would be postage on top for both ways.
so really its £280 then
Threads: 58
Unless you can find a cheaper alternative, I was only using my previous sent axle as an example.
Threads: 92
43
Where are you in the south west?
Threads: 58
Ill take one of these around about April time
Threads: 58
I've already cut you a good enough deal Mr on yours!
Threads: 465
114
Car Model/Spec: Vauxhall
if your collecting it Niall i expect a visit!
(23-01-2015, 09:29 PM)cully Wrote: if your collecting it Niall i expect a visit!
Only if that kettles boiling
Threads: 465
114
(23-01-2015, 09:35 PM)Niall Wrote: (23-01-2015, 09:29 PM)cully Wrote: if your collecting it Niall i expect a visit!
always is
Threads: 58
Just bumping this up, few people have taken advantage of this.
Threads: 102
18
Might take you up on this in the next couple of months!
Threads: 58
no problem give me a pm when your ready
Threads: 210
Car Model/Spec: Ph1 White Gti6/306 DTurbo
Given 7 thank(s) in 7 post(s)
27-02-2015, 08:23 PM
(This post was last modified: 27-02-2015, 08:23 PM by Nathan1305.)
Collected my beam today for my 106 and really impressed with it, Stef does great work on these  highly recommended
Threads: 58
Thanks nathan glad your happy with it
Threads: 125
Car Model/Spec: HDi Estate
Ive got my old estate beam in the garage, with serious camber which was why I changed it, its been sitting for a year though, What can you do with it?
Threads: 58
Providing it hasnt nackard the tube then i can do what ever you require me to do.
Threads: 142
58
Car Model/Spec: E46 BMW 320d
21-03-2015, 05:23 PM
(This post was last modified: 21-03-2015, 05:26 PM by WiNgNuTz.)
Just as a matter of curiosity, what sort of turn around time are we looking? Just wondering, as my beam is showing signs of camber, and could benefit from a refurb, but haven't got a spare to replace it with.
Alternatively, would you consider some sort of exchange arrangement?
Threads: 58
ive a gti spec beam here minus the arb that i could do on a exchange basis if you like but would need the same spec in return. No more than a week, as i order parts as and when i need them.
Threads: 142
58
Ok, well I don't have that kind of money to spend on a beam refurb right at the moment, but at least I know it COULD be a possibility. Might try and lay my hands on another beam to send off though rather than having to rely on you having the one I need.
Threads: 58
no problem, like i say ive one here i can build and swap it for yours
Threads: 58
just bumping this up for anyone thats interested.
I can also offer my top rebuilds these are on a exchange basis, they are fully inspected before and after strip down, heavily de rusted and painted in oem colouring. New bearing, seals, cups, shafts, arb seals, bushes and new bolts including shock bolts. Set to your required height and well greased and copper greased used where needed.
For this service i offer discount to forum members at £280
Stef
Threads: 371
29
Car Model/Spec: ford fiesta
Well ill be after one end of summer I reckon. I'll have a chat with you at fcs when I meet you. Lo
Threads: 58
Look forward to it
