Alternator Pulley
Alternator Pulley
Trying to take out the pulley from my nackered alternator to swap it out and put on an alternator from peugeot 405 but haven't got the proper tools to get the multispline bolt any tips on how to get it undone??
umm BUY the correct tool!
GTI6 Info
I've got the multi bit but i can't undo it with out the pulley spinning!
You need the other tool to counter hold it...
(17-01-2015, 04:30 PM)Toms306 Wrote: You need the other tool to counter hold it...
what tool is it??
18" stilsons
GTI6 Info
Tbf I read it wrong, thought it was a clutch pulley, not sure if they're the same!
If they are, you get a multispline outside with a hole through it so you can counterhold that while undoing the centre bolt.
(17-01-2015, 05:05 PM)Toms306 Wrote: Tbf I read it wrong, thought it was a clutch pulley, not sure if they're the same!
Okay will give it ago!
